Scott
Yes, this is the issue. If you have access to another LC or to a Plus, SE, or Classic, note the difference. This is not what that music...
Aug 14, 2026
V
VeryVon
Sure, here's what it sounds like on the LCII in System 6.0.8, on internal and external speaker. I can hear what you're talking about...
Aug 14, 2026
360alaska
Neat! Have you considered using an Ipad screen?
Aug 14, 2026
fishgee
If you can only get the top or bottom of the image in focus, it would seem to me that your camera wasn't re-mounted precisely parallel...
Aug 14, 2026
D
danhendleydigital
I've been using the latest version a lot recently and the freezing issue is completely solved. The only problem I'm running into is that...
Aug 14, 2026
S
sheppy1
SE30 Video Issues
Jut to close this off and in case anyone has the same issue in future. The problem was UG8 and the chip I'd used to replace it. I'd gone...
Aug 14, 2026
PL212
BlueSCSI Toolbox - NeXT Edition
Wow, was not expecting that level of polish! I don't know your comfort level with sharing the source code, but i'd be glad to try and...
Aug 14, 2026
Have a FAT build for 68k,x86,SPARC that works on 4.2 - I'm going to guess 3.3 will need a lot different GUI/WM calls.... Obviously some...
Aug 14, 2026
Froggy814
You are soooo right... This is now something I will let the experts do, instead of soldering the pi together and designing that myself...
Aug 14, 2026
Scott
OK, what hardware do you have it on? I can tell it's System 7.5 from the menu bar. I have never tested Midnight Rescue under System...
Aug 14, 2026
No, we have this part. We need the full register dump. Thank you for trying it, though - proves it's not just my hardware, but what ROM...
Aug 14, 2026
