K
ktaggart
BlueSCSI Ultra & Ultra Wide
Awesome, that fixed it! Here are some numbers for you. Boot to login screen: BlueSCSI: 8min 32sec BlueSCSI Ultra: 2min 33sec Login to...
Aug 24, 2026
caver01
I think you showed that in the video with a short mouse/kbd dongle attached. I am tempted to add a second one now that I removed the...
Aug 24, 2026
:slaps forhead: - well i actually fixed this back in May but got busy and didn't push the fix! You can see BlockSize is detected as "9"...
Aug 24, 2026
What the SIT?!
https://github.com/mihaip/machfs has bug fixes for https://github.com/elliotnunn/machfs to create HFS disk images that pass Disk First...
Aug 24, 2026
Gossamer Desktop Cooling
I used the fan from the back of an intel iMac in my Beige G3. See this post. Mine is a G4-450 overclocked to 533MHz.
Aug 24, 2026
ESM-NL
This problem is already solved. What I did not mentioned was that I used a USB extender, because of the way the two BlueSCSIs are...
Aug 24, 2026
croissantking
You don’t need additional cooling for a 7400/400 in a Beige G3 DT, the Power Supply fan will draw air across it adequately when the case...
Aug 24, 2026
ESM-NL
Here is the Jackhammer manual. The SCSI Manager 4.3 is yet downloaded and put in the system folder (and on more macs too). I start up...
Aug 24, 2026
Can you attach the manual here? I'd like to understand what its capabilities are. I've upload SCSI Manager 4.3 here...
Aug 24, 2026
K
ktaggart
Hello, I have been running a BlueSCSI card (50-pin, external enclosure) on my SPARCstation20 for a while now without issue - other than...
Aug 24, 2026
ESM-NL
I have a downloaded version of the manual. I don't have SCSI Manager 4.3 installed right now, but I look it up. My setup is as follow...
Aug 24, 2026
BlueSCSI Toolbox
Two new BlueSCSI Toolbox platforms have entered! BeOS GS/OS on the Apple IIgs...
Aug 24, 2026
