Radius FPD/SE clone with Rotation Transform and Output from HDMI of FPGA Project Board
Hardware
I'll edit in the other threads leading to this. Spent a bit of time with Claude Code this evening, here's what Mr. Code laid out:
Friday at 3:52 AM
Garth Beagle
You can safely test the power adapter voltage by using a bit of heat shrink tubing around the center pin in its connector so that it...
Friday at 3:51 AM
Here are photos of my power adapter (I have two):
Friday at 3:47 AM
Apple Lisa 3d Case Project
Well, I tried putting something together today that involved a usb-c breakout board type device, some resistors and a capacitor to try...
Friday at 1:55 AM
I have the 2nd Gen. Wallstreet called the PDQ which has not Reset button on back. Instead PDQ owners must press Shift + Fn + Control +...
Friday at 1:49 AM
PL212
Macintosh IIx - Manufactured Feb 1991. What??
Great research, and indeed a wonderfully clean example! I can easily imagine them using up the last few cases and motherboards into...
Thursday at 11:45 PM
L
litriSE
Mac Plus 820-0174-A: pulsating vertical-line pattern, no bong, good sync — TSM and LAG cleared via custom PAL exerciser. Where next?
I pull the last three remaining chips in the jellybean section - 74LS257 U2G, 74LS393 U1F, 74LS393 U1G. The 74LS257 in U2G was bad and...
Thursday at 11:31 PM
This Does Not Compute
It's been a while since I've used my Wallstreet, but I've had other PowerBooks (like the 2400/3400) sometimes behave the same way. I've...
Thursday at 11:19 PM
This article mentions the IIx being discontinued: https://tidbits.com/1991/03/18/apple-bargain-basement/ It's from March 1991, and...
Thursday at 11:15 PM
