G
GVD
Replace Power Macintosh G3 Beige mini tower PSU with a new ATX PSU?
Update in case anyone is looking to replace their PSU with a modern ATX one. I used this ATX2G3 Conversion Cable, 20-pin male to 24-pin...
Aug 30, 2026
Apple Lisa 3d Case Project
Noted. My thought was that PicoPSU handles everything you might need done cleanly/plug and play, using off the shelf components without...
Aug 30, 2026
I'm hoping to keep it cheaper and people can use a sufficiently rated 12v power supply. I think the 5v controller board that came with...
Aug 30, 2026
B
Boojakascha
I have that issue too, but I accepted it, because it's part of the secret sauce. Being zoomed out fully makes it such that you use the...
Aug 30, 2026
You could try grabbing my fork of Alex's repo and installing the version I have that allows you to run 1024x768. The image isn't quite...
Aug 30, 2026
jibsaramnim
Can Someone Help Me With This?
Apologies! It's entirely possible I've made some glaring mistakes here that are getting in the way. I wrote the entire thing up in the...
Aug 30, 2026
Radius FPD/SE - Rotation Transform/HDMI Output via FPGA Project Board - CLAUDE SESSIONS
Yep! It's wonderful to have a Reverse Engineering Partner who understands my "AI8 Coloring Books!" :) edit: I usually wind up talking...
Aug 30, 2026
I started from the board connector to the VRAM ICs. First notion was to interface there in order to capture frame buffer, eliminating...
Aug 30, 2026
Second interaction with Mr. Claude Code, thought it might be interesting: ______________________________________________________ Maybe...
Aug 30, 2026
Froggy814
Is that the schematic for the PCB you are building?
Aug 30, 2026
Aug 29, 2026
S
Scorpio_ny
Walkthrough - Replacing the Optical Drive in a G4 Cube
Thanks for the post! It is good to hear from other people’s experiences with different gear. Especially when some parts used earlier may...
Aug 29, 2026
