Froggy814
Also once you keep it plugged in for a while feel everything before turning it on to see if it is hot, (if it is torn apart) that might...
Sep 1, 2026
Froggy814
Do you get any sound or video out externally. (I am not acquainted with these machines so I don't know if they have ext. video or...
Sep 1, 2026
I sincerely appreciate you’re having made time to give me advice. Unfortunately, I know from firsthand experience that desoldering...
Sep 1, 2026
Froggy814
I didn't mean to say that the capacitors were the problem, I was just telling you what I heard from other people about the older...
Sep 1, 2026
Well, remember there are five electrolytic capacitors on the main DC board that sits between the two drive bays. Those are the only...
Sep 1, 2026
Froggy814
Capacitors most likely. I have heard that if you leave a PowerBook 1xx series plugged in for a couple of hours that the capacitors that...
Sep 1, 2026
Something good but strange happened today. I accidentally left the Apple AC power adapter connected to the PDQ and to the wall socket...
Sep 1, 2026
K
ktaggart
BlueSCSI Ultra & Ultra Wide
I upgraded the fw, removed the quotes and extraneous settings, shortened the image file names (just in case), and here is the log (note...
Sep 1, 2026
First - corruption in the log one is an easy one - you're using typographic quotes instead of normal quotes "". - ini should be plain...
Sep 1, 2026
Fitting Big Disks to G3s and G4s
I don't know of any reason why any Mac with an IDE connector can't support LBA-48 except for the drivers. Drivers can be replaced. The...
Sep 1, 2026
P
PappaDF
Yes, in principle it's possible to boot Mac OS with the "prototype" rom in the emulator (I've tested with system 7.6). However, let me...
Aug 31, 2026
K
ktaggart
As indicated in my last post, I am now attempting to convert my SGI systems to BlueSCSI Ultra-Wide. I am starting with the Octane 2...
Aug 31, 2026
