AlexCL
PiStorm on the Macintosh SE
https://github.com/Frimples/pistorm-macse-scsi-addon
Sep 16, 2026
AlexCL
Sep 16, 2026
AlexCL
Sep 16, 2026
AlexCL
Huge Milestone for PiStorm on the Macintosh SE tonight! I was working with an AI agent to try to get a virtual disk system working so I...
Sep 16, 2026
PL212
Snow EMU - Emulator for 680x0-based Macintosh computers
Bin/cue with audio tracks works as well, which is fantastic:
Sep 16, 2026
PL212
Fantastic -- checked out from your PR and: Thanks for both the fix and explaining how you researched it. I'd never played around with...
Sep 16, 2026
Radius FPD/SE - Rotation Transform/HDMI Output via FPGA Project Board - CLAUDE SESSIONS
Mini update: - I've annotated the pinouts for every IC with Claude's guidance - Completed the Solder Side tracework - Reoriented the...
Sep 16, 2026
continue the PCB reverse engineering project New file config check: New AI9 file created for buzzing Component Side connections from...
Sep 16, 2026
I dug into this with Snow's SCSI trace and the 4.0 driver. Apple CD-ROM 4.0 (DRVR 32 ".AppleCD", from CD-ROM Setup.image on the 7.1 CD)...
Sep 16, 2026
Apple Lisa 3d Case Project
Right now the plan was to just use a standard Pi. I've found the Pi 3b to be too sluggish for the LisaEm emulator, so I yanked a Pi4...
Sep 16, 2026
PL212
My host machine is actually Golden Gate, as of today. The emulated machine is a IIcx with a Toby cared running System 7.1, installed...
Sep 16, 2026
