K
KennyPowers
Is it an SE or an SE/30?
I have one like that labeled "Superdrive" where someone had added a 3rd-party aluminum HD sled allowing a HD to barely fit between the...
Oct 2, 2026
D
Doctorkillbydeath87
Wow, I indeed did not! When I was making up my digikey cart I must have accidently replaced the 8.2v zener with an additional 18v! I put...
Oct 2, 2026
S. Pupp
Although less common, the SE's labelled "FDHD" and "Superdrive" could come configured with two 1.44 MB floppy drives instead of a floppy...
Oct 2, 2026
jonschultz
Yeah I agree, the DF2 voltage is suspiciously high. Do you have the correct value for RF11, which biases DF2? I think it should be 370 Ohms.
Oct 2, 2026
D
derFunkenstein
Disk Jockey, a disk image file maker for your retro stuff - Beta for version 3!
Thanks to this thread (and of course Disk Jockey - thank you @OneGeekArmy!!), I was able to get my LC II + Apple IIe card booting with...
Oct 2, 2026
S. Pupp
If not done already, I would evaluate for barrel plug PCB failure by exchanging the barrel plug PCB's between the two PDQ's: - If the...
Oct 2, 2026
Mark_W
DL21/22 voltage is ok, but DF2 voltage is much higher than it should be (8.2V). Did you install the correct zener diode? Also double...
Oct 2, 2026
melw
Hi @Boojakascha - that sounds really unfortunate! Just to be sure I've got the details right: You modded the camera in the unit and...
Oct 2, 2026
B
Boojakascha
The problem first appeared while running a melw Type D firmware and since then I reflashed to a more current melw firmware. I have not...
Oct 2, 2026
D
Doctorkillbydeath87
Thank you so much, I was able to spend a little bit of time tonight trying out these suggestions. I'm not overly familiar with reading...
Oct 2, 2026
NuCF — Super Fast PDS-slot Hard Drive by ZZJ
I cannot speak on behalf of the creator, @zigzagjoe , but my guess is No, based on the fact he only specifically mentioned the SE/30...
Oct 2, 2026
