melw
Ok, that's another report on the same topic. Let me share a new build that prints the firmware version also in the splash screen to be...
Oct 9, 2026
jonschultz
Mystic Color Classic Screen Distortion
Yeah, the bulging is bad and a fairly typical problem on Color Classic analog boards, precisely because of the heat generated by those...
Oct 9, 2026
nilobject
#ev3
ported using the Aeorofoil source
Oct 9, 2026
melw
Thanks for reporting! On my unit, "FW 270" in yellow at the top right is visible all the time, so if nothing appeared at all, I'd like...
Oct 9, 2026
christcc2
Next question. Should the 3300uf 16V look like it’s bulging at the top, and thoughts on these two diodes that look burnt underneath?
Oct 9, 2026
Apple Lisa 3d Case Project
One thing I need to check on. Got some reason, I now get a message on power-up about the "Built in parallel port: unconfigured". I...
Oct 9, 2026
JohnCT
As far as I know, the camera itself is fine, but the optics are the biggest bottlneck. There are people who replace the lens to gain...
Oct 9, 2026
mmu_man
Poor eMate needs fixing
Turns out there's a cut trace on the membrane. I tried conductive ink but it didn't work, I'll see tomorrow if it just needed to dry out.
Oct 9, 2026
BajaTym
PowerBook 180c -- Vertical White Column Lines
Just a little rant... I have to say, IMO, desoldering old capacitors is pain. After pulling the first one, I discovered a bit of...
Oct 9, 2026
XodiumLabs
Harman/Kardon Soundsticks subwoofer potentiometer?
That looks about as close to drop in as I’m going to get, heh. I’ll measure up mine but this looks like the closest fit. Thankfully...
Oct 9, 2026
