ried
Options for hard drive replacement
The internal Widget hard drive can be replaced with: X/ProFile by SigmaSevenSystems, sold by VintageMicros (currently being...
Friday at 5:10 AM
melw
Videos saved with custom firmware are using higher bitrate than the stock firmware. Built-in playback likely can't handle this. 64GB...
Friday at 5:06 AM
melw
Type D — FW 271: build number on the start-up screen Firmware version added to start-up screen ("Type-D - FW 271") No other changes...
Friday at 4:53 AM
melw
Ok, that's another report on the same topic. Let me share a new build that prints the firmware version also in the splash screen to be...
Friday at 4:34 AM
jonschultz
Mystic Color Classic Screen Distortion
Yeah, the bulging is bad and a fairly typical problem on Color Classic analog boards, precisely because of the heat generated by those...
Friday at 4:30 AM
nilobject
#ev3
ported using the Aeorofoil source
Friday at 4:25 AM
melw
Thanks for reporting! On my unit, "FW 270" in yellow at the top right is visible all the time, so if nothing appeared at all, I'd like...
Friday at 4:03 AM
christcc2
Next question. Should the 3300uf 16V look like it’s bulging at the top, and thoughts on these two diodes that look burnt underneath?
Friday at 3:35 AM
Apple Lisa 3d Case Project
One thing I need to check on. Got some reason, I now get a message on power-up about the "Built in parallel port: unconfigured". I...
Friday at 3:33 AM
JohnCT
As far as I know, the camera itself is fine, but the optics are the biggest bottlneck. There are people who replace the lens to gain...
Friday at 3:08 AM
mmu_man
Poor eMate needs fixing
Turns out there's a cut trace on the membrane. I tried conductive ink but it didn't work, I'll see tomorrow if it just needed to dry out.
Friday at 1:11 AM
