K
kaleokeanu
SE/30 mystery issues...
For future reference, I struggled to get the bourne's filters out, destroying 1 in the process. Turns out they were all perfect...
Oct 14, 2026
D
Doctorkillbydeath87
Thanks! I metered those two points and it looks like my voltage is decent, I also measured each end of the resistor: RV26: 7.95v/8.1v...
Oct 14, 2026
jonschultz
When a CC seems to be this dead, I recommend checking some of the low-voltage supplies. Many of them will normally be running even...
Oct 14, 2026
D
Doctorkillbydeath87
Well, I seem to have a new issue with the machine... I finished recapping the entire analog board, installing the correct diode...
Oct 14, 2026
PowerBook 160 BlueSCSI WiFi External Antenna, Termination Power, and CMOS battery replacement
Very nice and period correct indeed. Nice touch that you can easily remove the antenna, conserving portability. Can't think of the name...
Oct 14, 2026
LisaNet - remote management of ESFloppy and ESProfile images
Added the ability to control the settings from the ESP32 web UI. (Ignore the error on the screen, I had powered off the lisaFPGA when k...
Oct 14, 2026
Superpops99
Help with C43 in Quadra 610
Thanks for the quick reply! I found the same picture, and some others... I am just not sure if that can be replaced as well... I suppose...
Oct 14, 2026
chuck.dubuque
610 schematics seem to be unobtanium, but... Recapamac has a high-res photo of a 610 MB at https://recapamac.com.au/quadra-610/ If...
Oct 14, 2026
nilobject
#ev3
https://x.ai/bot/mkGAa1tZ2QPZ6jFQ2j2bA
Oct 14, 2026
