jonschultz
For IP7 pin 6 on my system, with hard-power on but soft-power off, I measure -55V relative to chassis ground and 0V relative to the...
Oct 18, 2026
KeroBurn: a Mac app for the XGecu T48 / TL866II+ (beta, testers wanted)
The latest revision of the board has an extra address linenfir the ROM so people could test using the Classic ROM, as they're identical...
Oct 18, 2026
D
davesmuseum
Hello from an SF Bay Area collector—and an introduction to Dave’s Computer Museum
Hey All! Thank you to everyone who has stopped by my computer museum site (davescomputermuseum.com)! I’ve been having fun the last...
Oct 18, 2026
lrdgreen89
In Deano's Hardware Upgrade post #199, the comparison photos appear to show improved contrast when using the 3mm aperture hole cover...
Oct 17, 2026
jonschultz
I think that whole section is floating relative to ground because it’s effectively on the AC side. The AC side and the secondary sides...
Oct 17, 2026
D
Doctorkillbydeath87
I measured pin six with my meter set to DCv & ground lead contacting the shroud surrounding the main supply plug socket. Attached a...
Oct 17, 2026
B
blturner
Radius Pivot Display flipped menu bar
I recently got this Radius Pivot model 0361 and, after much finagling with the DIP switches on my VGA adapter, got a decent picture...
Oct 17, 2026
nilobject
CodeWarrior
Hexx68K - A strategy game for 1 or 2 players
Yeah I think it’s just the music causing issues. I was emulating a maciix system7.1
Oct 17, 2026
Mark_W
53.8v is way too high, should be around 10-20v IIRC. Also ip7 is on primary side so you need to measure the voltage of it regards to hot...
Oct 17, 2026
D
Doctorkillbydeath87
I've inspected the board thoroughly and found one detached pad @ cv19, bridged with wire to the nearest connection (DV4). Confirmed all...
Oct 17, 2026
Kay K.M.Mods
@PL212 Thanks for the report, and great to see it working on an M5 Pro with macOS 27! That looks like one of the early betas. Since then...
Oct 17, 2026
