I
indibil
ADC to HDMI graphic card conversion
PowerPC G3, G4 & G5 (New World ROM)
Hello. Some time ago, I set out to replace the ADC ports on certain OEM graphics cards with an HDMI port. I finished the project a...
Oct 25, 2026
celery_man
Hello all, wanted to report successful scanning with Type D Firmware (FWDV280.BIN) on a unit with "M2025148BKXXXXX" serial. I will try...
Oct 25, 2026
T
todd95008
I removed 2 springs from the 2 film hold down clamps. The outer left spring and the outer right spring leaving the 2 inner springs. This...
Oct 25, 2026
stynx
I looked into the HDD-dump a bit (the iso file) and there is a lot of stuff in there that was not deleted when the partition was...
Oct 25, 2026
OK, here is my first draft of the Mac OS Extensions pack. I am now pretty certain I can't boot the internal SCSI with the onboard ndrv...
Oct 25, 2026
A
Appelsientje
JASONDOESITALL Adapter for 17" ADC CRT Monitor
Maximum Continuous Power: 113W is what the CRT is rated for. 24v and 5 ampere should be able to deliver 120W is my math is correct.
Oct 25, 2026
I don't know about the CRT model, but all the LCD models work fine at 24v. I haven't seen actual 28v come out of any of my G4 tower ADC...
Oct 25, 2026
A
Appelsientje
Are you sure about the 28V? The power adapter that gets recommend is 24Volts and 5 ampere. Also, what should I enter in the...
Oct 25, 2026
1oz copper should suffice, 28v DC is what the ADC uses -...
Oct 24, 2026
nilobject
#ev3
Oct 24, 2026
Marcio D.
ELDEMAR: A New First-person Fantasy RPG / Action Game for AGA and RTG Amigas !
A new stretch goal has been introduced! If the campaign reaches €7,500, a high-resolution mode will be included in the game...
Oct 24, 2026
