Logic Board - Macintosh SE Reloaded
@Kai Robinson can correct me if I'm wrong, but I believe the SE Reloaded board layout began during the 2020 COVID lockdowns. The board...
Oct 26, 2026
JASONDOESITALL Adapter for 17" ADC CRT Monitor
I built a few of these and never had much luck with them. I did put one together and sent it to another user on this forum who was able...
Oct 26, 2026
Kris92
I'm working this way (a bit). I added direct support for both Apple ROMs and 27c010 EPROMS. RC filters can be originals ones or SMD...
Oct 25, 2026
Arrowhead
Macintosh LCII failure
Doesn't the LC II have 256k of VRAM on the motherboard? I have tried both it's original hard drive and my external BlueSCSI, all the...
Oct 25, 2026
Mark_W
Is VRAM installed? LC II has no onboard VRAM and if no VRAM is installed, it will boot to a blank screen. Also try a different VRAM...
Oct 25, 2026
Mark_W
So like I said primary side should be ok, if you see around 10v across pin 4 and 6 on TDA4605 then it should try to start, and you...
Oct 25, 2026
JohnCT
Your post triggered a memory... years ago I used to repair 8mm and Mini DV camcorders - 10 or more a week.. A problem I saw often was...
Oct 25, 2026
Claus
Hi, and great thanks to all effort with the firmware D. It works great, I use now 270 and will upgrade to 272 soon. I have two questions...
Oct 25, 2026
K
Knife Cult
This was probably routed before most of the CAD tools were in good shape. It looks like there is a lot of cleanup that could be done...
Oct 25, 2026
Kris92
Does someone know why A19, A20, A21, A22 routing from the CPU to the PDS slot and the BBU use so a long path ? Is it to avoid a timing...
Oct 25, 2026
