AlexCL
PiStorm on the Macintosh SE
Update on status of project: -128 MB of extended memory working. -68040 CPU working internally with RAM, ROM and Software Accessories...
Nov 15, 2026
wells
If you have already turned on auto-mute, running the updater won't change the setting! Thanks for asking, I updated my previous post to...
Nov 15, 2026
melw
Hacking the Reflecta DigitDia Evolution (Novatek NT96660) Slide Scanner
Hello all! Another update and first test build ready for sharing! 12. The patch-loader approach It uses the same run-from-SD trick as...
Nov 15, 2026
melw
Type D FW 292 is attached. Two fixes: Fix corrupted screen when zooming out in frame adjust. This was a bug in Kodak's own firmware...
Nov 15, 2026
Balto1986
From v.2 update for type C For Scanner Type C. Use the existing reframing controls to scan everything the sensor sees This is great...
Nov 15, 2026
Fascinated by some of the Snow White prototypes - So I made one
OK, final version is printed and I think it turned out pretty nice. I added a spot for an old Apple logo from a damaged case...
Nov 15, 2026
lilliputian
Finding a specific DRAM chip for PB500
It took a few years, but an inexpensive module finally showed up on the bay that had the specific RAM chips on it that I need! Before I...
Nov 15, 2026
techknight
Programming for the Compact Macs - new IDE
Oooh, this reminds me of B4X
Nov 15, 2026
techknight
Mac Plus: beep, blank white screen, then shuts off after ~3 sec
Thats a logic board problem. PSU is staying on, its the ROM trying to start and it blanks the display instead of drawing out the next...
Nov 15, 2026
melw
Thanks for the detailed report and the photos, and glad it's working now! What you ran into is a bug in Kodak's own firmware. It...
Nov 15, 2026
I
indibil
Issue with the power button on a Cube
PowerPC G3, G4 & G5 (New World ROM)
Hello. A friend of mine has a Cube that recently stopped booting. He brought it to me, and after thoroughly cleaning the motherboard...
Nov 15, 2026
