360alaska
Macintosh Games ported to W10 with Claude
Claude: Here's the full list of changes in the port since the first build I sent you. 1. Flashing floor outlines (fixed) The tan...
Nov 19, 2026
A
alexanderlewis
Before you tear into it, photograph or sketch the washer/spring order and keep the removed washer labelled—that makes it reversible if...
Nov 19, 2026
I
ioeuqr
Got it, thanks. Sounds like a full disassembly instead of the simple fix I was hoping for. No problem, I've been in there a few times...
Nov 19, 2026
A
alexanderlewis
QuickDraw Speed - Fast Card Benchmarks
Lines being the weak spot isn't too surprising: many NuBus QuickDraw drivers accelerate blits and fills but leave general line...
Nov 19, 2026
JohnCT
I took the back off the reels, removed the motor, and disassembled the hub. There were two washers on either side of a heavy spring...
Nov 19, 2026
Fascinated by some of the Snow White prototypes - So I made one
For this one, I had a spare Apple logo that came from a damaged case that I popped out and have had sitting in a drawer. With a...
Nov 19, 2026
Froggy814
THAT is AWESOME!!!!!!! How did you do the badge?
Nov 19, 2026
I
ioeuqr
I totally get it. Just quickly then, did you have to go through the back of the machine and remove the motor and gear set? Or were you...
Nov 19, 2026
JohnCT
I did not take any photos. I'm up to my ass in alligators right now with several projects (I have my house ripped apart doing a full...
Nov 19, 2026
