O
Oelmuvun
Transplant G4 hardware to a PC case
After removing the ATX case's standoffs(if it came with any installed), populate your PCI and/or AGP slots. At a minimum the top and...
Wednesday at 1:11 AM
O
OldeGuysSE30
ADB Connection Adapter
Thank You!
Wednesday at 12:08 AM
Yes! @Tashtari invented one. Details here...
Tuesday at 10:13 PM
reallyrandy
Options for hard drive replacement
Yep, I figured that out. Thanks! I had to use terminal on Mac since disk utility no longer supports fat32.
Tuesday at 8:34 PM
alex_santos
Thanks for the reply. I'll check out those sites on the Wayback Machine. Hopefully, I'll find a guide or a post from someone who has...
Tuesday at 7:37 PM
O
OldeGuysSE30
Compact Macs
Novice question here: Anyone found a solution that would enable connecting a male PS-2 (on a Cherry mini-keyboard) to the 4-pin mini-DIN...
Tuesday at 7:32 PM
T
tor_z
You need to format the SD card in FAT32 (not EXFAT), as outlined here: https://github.com/alexthecat123/ESProFile#sd-card . Note that...
Tuesday at 7:31 PM
reallyrandy
So I got the ESProFile delivered. I installed it by mounting it to the old drive cage. I formatted a 128GB Samsung EVO Select as exfat...
Tuesday at 7:20 PM
B
Boojakascha
Out of curiosity, did any other D owner attempt the hardware mod and found themselves with too much zoom? What kind of lens/spacer did...
Tuesday at 5:58 PM
sgerstacker
ImageWriter II Ribbon Cam Assembly Layout?
I've been fighting with an ImageWriter II for a while. I realized that some of the diagrams in the service manual are confusing and...
Tuesday at 4:05 PM
