Grey Clamshell G3 LCD Replacement?
1,340
scsi.blue
Got a gray clamshell in the mail and though packed very carefully and lots of bubble wrap, something must have hit it just right to flex the LCD:
It seems like these are fairly common parts - any caveats or suggestions for a replacement as I start looking?
3lectr1c
614
282
the United States
www.macdat.net
Apple used multiple different LCD manufacturers, and to my knowledge none of the cables are cross-compatible. If you do find one that is of a different brand than the one inside it now, you'll need to make sure it comes with the cable as well.
This Does Not Compute
215
342
Instead of searching for keywords like "iBook LCD," you'll have better luck disassembling the display housing and searching for the part number off of the LCD panel itself. There seems to be a cottage industry in China that refurbishes older-model LCD panels -- I suspect it's primarily to serve the industrial controls market (CNC machines, etc) but I was able to find a replacement panel for my Duo 270c this way.
davidg5678
37
I think the LCD panels from several other iBook G3 and G4s from this era should be suitable replacements, but the challenge is making sure that you have the right cables to connect them to the logic board.
Something to note is that these iBook LCD panels can be upgraded with higher resolution parts than were originally installed. If you need to replace the LCD already, this XGA mod might be something worth looking into. See here for some more info:
It looks like there are possibly some software screen resolution glitches at startup, but once the computer finishes booting, you end up with more screen resolution to work with, which is pretty handy.
3lectr1c
614
282
the United States
www.macdat.net
That adapter part doesn't appear to be produced anymore (from the macrumors thread).
I've wanted to XGA mod a clamshell for ages but never saw it as reasonably possible. I've got 3 LCDs total so maybe I should see if any are the LG. I've also got a spare G3 Snow 12" display...
All my clamshells are the 1st gen 4MB video models, so they wouldn't work anyway...
davidg5678
37
I did some research, and I think this link is for the same part number. It seems like it is still available for sale to me: https://www.pchub.com/uph-oecv022-lcd-cable-converter-20-to-20-pins-x-20mm-p30800
