ThinkC Extracting source code files so I can save in github
RickLawson
Boiling Springs, SC
Has anyone found a reasonable way to extract their C source code from minivmac so that it's easy to push to github with normal line endings?
I found this project (which is Java) https://www.catacombae.org/hfsexplorer/ that allows me to explore and extract files from a mini vmac dsk image
I was thinking of writing a utility based on this project that would sync a folder in minivmac with my workstation.
I'd like to not have a gui and just run a command and have it sync from mini vmac dsk image to my local workstation so I can push to github.
But I don't want to reinvent the wheel if there is an easier way
1,305
scsi.blue
I'm away from my computer but a few notes on things I've done:
Use hfsutils cli apps, work OK.
Retro86s tool chain has a way to sync with vmac.
Basalisk has a shared folder functionally
There are a few python libraries for hfs and resource forks.
RickLawson
Boiling Springs, SC
Ok yeah I found this which should allow me to script up what I need to do
I'll post it here when done
In my case I'll have a config file that takes mappings from src folder on the minivmac volume and destination folder on my workstation and will export when ran so I can commit to github repo
Reactions: eric
RickLawson
Boiling Springs, SC
Ok checked in some python scripts at
Used them to sync up my C code from minivmac and everything seems to be formatted nicely
Suggestions and merge requests welcome!
