Where to get ZIP VRAM for NuBus Radius DirectColor video card
bcl
I have a DirectColor card with only the soldered-in 8 × 1 Mbit RAM (i.e., it's a DirectColor/8 with 1 MB VRAM). I would like to make it a DirectColor/24 with 3 MB VRAM but I can't figure out where to get ZIP VRAM chips. I presume nobody has made them for a long time, but does anyone know where there might be some NOS available?
Here are some - pricey though:
These are a bargain for 3 pieces:
Looks like almost all 1mbit ZIP28 RAM is 256k x 4-bit multi port DRAM.
OKI MSM514262 would also likely work.
bcl
These are Micron, but does it appear to be the same thing? I know less than nothing about DRAM that's not on a SIMM.
I'm going to ask the seller to confirm it's 13 of them for that price, because the photo shows 2 and it says 23 available. 13 seems like a strange quantity to be in a tube from the factory, but maybe these are repacked.
Most DRAM in the same packaging are the same type of DRAM - JEDEC defined pinouts at least. Very few, if any RAM manufacturers choose to ignore the JEDEC standards.
bcl
Well I ordered enough for the two video cards I could immediately find that use it and aren't fully populated. It should be here tomorrow. The price was by far the lowest I could find. Thanks for pointing me in the right direction, and we'll see if this works.
Reactions: Kai Robinson
bcl
I added 16 ZIPs to the DirectColor/8 card. Before, Monitors control panel offered 256 colors. Now it offers Millions of colors (identifies as DirectColor/24). However, I did the same with a RasterOps 8L and nothing changed. The ROM on the Radius DirectColor card is labeled as "DIR. COL. 8/24," which suggests the card self identifies as one or the other based on how much VRAM is installed. The RasterOps ROM is labeled as just 8L, so it might need a different ROM chip to do 24-bit. On the other hand, one of the new VRAM chips might be bad or something else.
