[Very fluid] Classic Amiga demo Remade for b&w Macintosh (Vanlandingham)
Mu0n
697
672
Quebec
I came across this demo I had forgotten in some nondescript collection of graphics applications folders I had laying around. Some people in the Boston Computer Society took it upon themselves to recreate (in 1986) the 'boing!' demo from the Amiga which features a fake 3d bouncing ball animation, complete with sound, running in Workbench.
This fine piece of hackery involves color palette cycling to give the illusion that the ball is spinning on itself, so several areas of the balls are using the same colors spread out to distinct palette indices. By cyling the palette definitions around, the pixels are merely switching colors during a vertical blanking retrace instead of being calculated from a complicated linear algebra 3d transformation and some kind of raytracing 3d engine (wouldn't be possible on the original early 80's Amiga).
From a Macintosh standpoint, this is where it gets interesting. This was done fairly early in the black and white compact macintosh cycle (1986) so I'm not 100% certain the 'color' quickdraw palette was available. I half remember it was possible to set colored pixels in some apps that you'd still see in black and white on screen, but could be transformed into their proper color if you printed them with the appropriate colored ribbon printer. It's possible that the code used an entirely new data structure outside of quickdraw to deal with palette cycling, but I'm not solid enough on these matters where I could do my own code.
Still, with no special handholding done for you graphics wise (I'm thinking the lack of hardware sprite), it's quite remarkable that so many pixels are pushed so fluidly on this demo.
I made a small video about it if you want to see it in action, from a direct RGBtoHDMI video capture from my Mac Plus. I also included a bit on the Amiga version (emulated in WinUAE)
So, @Mu0n, it looks like the Mac ran the beach ball at higher frames per second than the Amiga? In other words, the beach ball bounced around faster? 😀 🚀
Did the Mac also recreate the BOING BOING BOING sounds? ⚽🔊
Mu0n
697
672
Quebec
We can't really judge that. The Amiga footage is based on my capture of the WinUAE emulator and its exact speed is dependent on cpu sliders in the options.
The Mac version had no sound. Which makes sense, because the freeform wave synth of the Mac plus takes a sizeable chunk of cpu usage %
jjuran
The eight-color system in basic QuickDraw was definitely there, but Vanlandingham doesn't use it, nor any kind of palette animation. It uses the page flipping feature of the original Macintosh graphics hardware for double buffering. So instead of being confined to work solely within the vertical blanking interrupt, it has an entire frame to render each buffer.
I recorded my own video of Vanlandingham running in Advanced Mac Substitute:
