Hello everyone!
I have been thinking for a while about video and ethernet cards for my SE/30. I want to get a 24-bit video card. I already have a short height ethernet NIC. An accelerator later on, too, once Garrett's Workshop or Bolle comes up with a modern accelerator for the SE/30 that is shorter in height.
So, that would be three PDS cards. I am aware that there are vintage PDS connector cards and that some video / accelerator cards have PDS connectors. In recent years, Artmix came out with a PDS connector / riser card, but it is limited to use with an accelerator and expensive.
There is a need for a modern solution now. It should be easy and straightforward to design the Gerber and go from there to PCB.
Is anyone on here interested to create a new and simple modern PDS riser card that will connect up to three PDS cards in the SE/30 with jumpers to adjust the slot addressing? The card needs to connect to the SE/30 PDS slot and clear the chassis. Then, it needs to have two PDS connectors on the side at approbate heights below and above the HDD and FDD. Finally, this card should have one more PDS connector on the top. It needs to be height appropriate to allow a tall PDS card connect and still fit in the SE/30 case. The point is to avoid stacking three miles high and breaking through the roof of the SE/30.
Any one want to get started?
