So, we're moving from a room in 2nd floor apartment, to a our own ground floor apartment with 2 bedrooms and a garden. Now, the Mrs wants to be able to have a garden space to herself and I have just the idea. In the garden is a concrete base suitable for a garden shed. This will not just be any ordinary shed - it will be a 'MEGA SHED'. I'll get around to explaining a bit more in a second.
Currently the base is a bit janky, so the plan is:
  • Break up existing concrete blocks to create a hardcore base material, fill the hole
  • Lay down concrete rebar mesh
  • Pour over readymix concrete with self-levelling compound & drying accelerant
That should be fairly cheap to do, as i'll be doing all but the concrete pour myself. The goal is to be left with a nice, flat base that'll be suitable for putting a decent shed on top.
Now the size hasn't been confirmed, but the pad looks to be perfect for a standard 8 x 6 ft (2.43 x 1.83m) to 8 x 8 ft (2.43 x 2.43m) shed.
The specific one hasn't been decided on, but the general line of thinking is a shed with windows on one side and a double door - something akin to this:
Good shed, right? WRONG! :D
It's just a boring shed - and not worthy of the title MEGA SHED! What makes it a mega shed? Well, here's the plan/half-baked-idea:
Interior walls lined with insulating material such as rockwool - marine plywood board over the top of the interior battens and roof to create a more weatherproof shed all round, more air-tight, warmer in winter, cooler in summer and also slightly more practical for mounting things internally.
The floor of the shed has to be more than the standard 3/4 inch (18mm) plywood bullshit - I want 1 inch thick (25.4mm) tongue and groove over treated hardwood joists, so there's an air-gap and water barrier between the floor and the concrete. However, I plan to place a thin polyolefin insulating sheet, then some more marine plywood between the joists and the tongue and groove, in order to provide more insulation and water/air resistant barrier.
Of course then there's the insulation of the door, similar to the interior wall panels, and installing a draft excluder 'step'.
This makes a mega shed? No! That's just a nice shed now!
So what now? We have a well insulated shed that's ready for fitting out - the plan now is...ADD ELECTRICITY!
However, the shed is a green space for more than just plants, why not make it entirely self sustaining? For this, we're going to need to go off-grid.
Now 250 to 360W panels are pretty easy to get hold of for cheap - and as the planned shed design is an 'Apex' roof, one panel per roof side would provide between 500 and 720W of input power (best case scenario). That should be enough for the load that'll be drawn on a bad day, but I still think we need some redundancy in case of long nights and really shite weather. BRING IN THE VERTICAL HELIX WIND TURBINE! They're surprisingly compact and less than a metre high and because it's vertical, it can be mounted anywhere in the garden.
These typically generate around 300 to 500W of power at a wind speed of 10m/s (22 MPH) - Of course, even in the UK, the wind speed rarely gets quite that high and is usually about half that. Most of the curves of the turbines are pretty stable, so let's be conservative and say 150 to 250W of usable power on average as a boost.
Feed both the solar and wind sources into an MPPT charge controller and feed the output into two 12V AGM (or potentially LiFePO4) batteries in parallel that can be partially hidden in the void space between the inner and outer walls. Total power? Well, if the solar is REALLY bad, say 50% from the solar gives us 305W of power. Add the wind at it's worst and we have 150W - we're at 455W - nearly HALF A KILOWATT!
Now the idea is, we don't need an inverter, we're not running anything that's going to require mains power.
Lighting will be all LED - four to eight short 'warm' temperature LED strips for general lighting. Each strip uses around 5 watts at 12v, so a total of 40 watts of power there.
For the grow lights - each of these is around 50 watts, and there's likely to be 3 of these - another 150W, bringing the total to 190W of power in total. This leaves 265W of 'spare' power. What can we do with this? Well, let's add a few USB power sockets and some 12v car-style outlets (for things like a dustbuster, phone charger, bluetooth speaker etc) - trims this back to 200W or so (assuming you're loading all of them simultaneously). Now what about what's left?
My final idea is - heating. During the summer, not needed, but winter in the UK can be bitter as hell and how nice would it make working in the shed if it's somewhere above freezing? There's plenty of ways to do this, but honestly, the best way i can think of, is to have a standard UK style radiator (easily obtainable for cheap) mounted on the far end wall, being fed by a small immersion heater. This would probably have to be custom made (or adapted from another application) to fit into a small size, to go next to the radiator. You can get 12v immersion heater elements, available in 100/200/300/400W ratings, for pretty cheap. Let's choose a 200W part. Fit that into the tank with a thermostat and make up a loop with a small 12v water pump, giving you a small, self contained central heating setup!
Connect the pump and the immersion heater to a timeswitch so that it's only active for a little bit overnight and you're being frugal with the batteries so as to not run them down too far. Coupled with the added insulation and hopefully, that'll keep everything nice and cosy. The ideal temperature would be around 19*c.
Now in the summertime, the heater would be mostly redundant, and instead you'd need something for airflow - so the idea was to build in some 12v PC style 140mm fans, although i've not thought about where or how, as that'll be dependant on the end shed design.
Now *that* is how we build a MEGA SHED!
660
That is one mega fancy she-shed. Is this space going to be specifically for growing stuff or will there be built in work space?
Also, water seems like it would be a nice addition considering the gardening going on. Heck, that could be as easy as a hose from the house to a shed hook up. What color is your wife making her new shed?
453
Modified salt box design facing south with (horizontally hinged at top) clerestory casement windows to vent hot air in summer?
Consider setting your joists (or just treated furring strips) on 2" rigid foam insulation? Usually installed vertically between concrete foundation and ground, but it would give you a waterproof, raised platform?
YMK
426
361
Interesting plan. If you have mice in your area, you may want to reconsider the finished/insulated walls. They have a talent for embedding themselves in walls and expiring, making the space unpleasant for the next six months or so.
If the main uses for the electricity are heat and light, I'd try to gather those as they come from the sun with skylights and thermal collectors.
Thermal storage can accumulate heat during the day (from either a thermal or PV collector) and release it during the night without putting miles on your battery system. This could be a residential water heater plumbed to a radiator, a drum of water with some insulation around it, etc.
A little bit of column A, a little of column B - the work is repotting things like monstera's and syngoniums.
Thankfully there's a photo of the garden as it looked in 2019, that i found here (also handy if you want to ogle the property as it was in 2019, too!):
That's easily an 8x10 shed on the same pad. The water is available from an external hose reel mounted on the exterior wall, so i could plumb in a T piece and have it fed to the shed via flexible garden hose.
What's a salt box design? :)
the joists sitting on something other than direct on the concrete...well, i wanted to put them on something that won't wick water, foam insulation would be great but can it handle the sheer weight on top of it? The only foam i've seen is brittle and doesn't do well with compressive forces.
453
New England winter thing that looks like an olde schoole salt container. Modern designs have an overhang above the tall, glazed side of the house to block the summer's high sun to keep things cool and let the low winter sun's light wash in when heating is needed.
Rigid foam stands up to earth berm and water pressure. Might not work, but it's far more dense than other foam insulation.
660
All I have to say is that is one righteous galley kitchen - just gorgeous. Very cool! Love the back yard space too. Hmm, the way it is oriented, the pad could be rebuilt to accommodate an even bigger she shed. If you do commence with the build, please document here. Id love to see how it comes together.
