Hey all, a while back, while doing some cleaning, I managed to damage one of my 3.5" Superdrives. It's taken me some time to narrow down the issue. I had just cleaned it and was testing disks, so I had it connected, just setting loosely in the chassis, I lifted the front to insert a disk, and I suspect it shorted something out when it touched the metal magnetic shielding beneath it.
The symptom:
Upon boot, the heads make no movement whatsoever, inserting a disk results in no movement, but eventually the OS wants to "initialize" the disk, which does nothing, so you can do nothing but eject, but that does work (at least i'm pretty sure eject worked... it's been a couple of months now!)
What I've tried:
Where I've landed is a 3 legged component labelled "B•6", and "Q4" silkscreened on the PCB:
Legs 1 and 3 have a short between them. All the other B•6 components on the board do not, additionally my known good drive shows no short across the same legs. When that component is in place, I also have a dead short between either end of the C17 capacitor just to the left of it in the photo. With that B6 component removed, I get no such short.
By now, you've probably guessed, I don't have a ton of technical experience with this, but I can troubleshoot... sometimes! What I'm looking for is the name of this component so I can source a new one... From my searching, it appears to be some kind of barrier diode, but, again, I'm not well versed in this.
Any help would be appreciated
The symptom:
What I've tried:
- Initially I suspected I'd shorted the controller TA7774P, but I've swapped that with a known good one, and no difference in the result.
- While waiting for 3d prints to finish, I decided to just start probing the board with the multimeter looking for shorts, and I found one:
