Snooper serial loopback plug
Branchus
528
Hi all,
The Snooper software (originally made by Maxa, then later by Central Point Software) used to include a NuBus diagnostic card as well as a small, black, serial loopback plug for testing the serial ports.
I'm not too fussed about the card, but does anyone have one of these loopback plugs, or even a diagram of the plug's wiring? I'd like to replicate it.
I assume it's just connecting the RxD to TxD, but I'd like to be sure.
Thanks,
Bruce
ITHistory (1993) Software Manual: Snooper Diagnostic (Central Point/ Maxa)  | #1999198717
splorp
179
Calgary, Alberta
splorp.com
I have one the Maxa Snooper NuBus cards (1.0) … but it didn’t come with the loopback plug. I wasn’t even aware that such a thing existed until now. I guess I need to read the user manual a bit closer.
Branchus
528
I don't suppose you could post some nice, clear hi res pics of both sides of the NuBus card please? I'd love to reverse engineer it.
craig
14
39
Dalry, Scotland
www.meerkats.uk.com
I've figured it out (and made a pretty diagram). I've tested this in Snooper and it passes the handshake and data tests successfully.
I hope it's of help to others.
Hi Bruce, thanks for figuring out the loopback connections. Just wondering if this same pinout also works for your printer port? When I do this on my printer port it is happy with the handshake lines but fails on the data lines. On the modem port it work perfectly.
Thanks.
Branchus
528
Thanks.
Hi Craig, yes it's the same for both ports. I've only tested it on a couple of computers, but it worked for both ports on both computers.
Reactions: rikerjoe
craig
14
39
Dalry, Scotland
www.meerkats.uk.com
Sorry for the delay in replying but I'm happy to say I got my printer port working. The cause of the problem was a PCB routing error on the Bolle SE/30 Reloaded PCB (Rev02) which Bolle has now fixed in the latest board files (Rev03+) on his GitHub site.
The pins involved should have been as follows:
RP3 pin 13 to UD12 pin 14
RP3 pin 14 to UD12 pin 13
...but were actually transposed.
After that was fixed (with some enamelled wire), I ran Snooper in automatic mode for a few hours and it successfully passed over 250 cycles with no failures in any sub-system. Happy days!
Branchus
528
So the little tester was actually doing its job with the failed test. Excellent!
Reactions: craig
rikerjoe
256
I made a serial loopback plug with a mini DIN plug I bought from Amazon and using the instructions provided by Bruce @Branchus earlier in the thread. The serial loopback plug worked great! I am troubleshooting two problematic SE/30s which have various minor problems. One failed the modem baud tests but passed the handshake (printer port tested fine), and the other, more problematic SE/30 failed at the handshake test on both ports and Snooper hung at that point. The printer and modem ports tested just fine on a series of other classic Macs. Time for more troubleshooting on both SE/30s! Of course, I welcome any suggestions from the wonderful TinkerDifferent community :)
2,227
I don't know if the color scheme for serial cables are standardized, but here's how mine mapped in case it might save you a few minutes when making your own.
I purchased this serial cable from Amazon Japan and can confirm wires are the same color scheme as you showed. I guess that means the colors probably are standardized.
Note that only one connector on the cable had colors which matched those pin numbers. The other connector has GRN on pin5 and ORG on pin3, and pins 1 & 2 are also reversed. That has no impact in how you make the loop-back connectors though, since 3 & 5 and 1 & 2 are connected to each other.
My handmade loopback connectors ("Serial Cable" link to Amazon USA in text description) work great with Snooper 2 to confirm proper operation of the two serial ports.
Thanks, @Branchus , for having kick started this important thread!
