Snooper serial loopback plug
They talked about it over at 68kmla, too.
AlexCL
68
Article on Snooper...
2,230
Restored for @JDW, @jajan547, and everyone else viewing this thread. :)
A bit off topic in terms of what this thread is about, but your post inspired me to try extracting all the cool logic board images the PICT resource of the Snooper 2.0 app using ResEdit & Resourcerer, but double-clicking and/or browsing the PICT resource instantly crashes both Basilisk II and Mini vMac hard. Probably will crash a real Mac too. Not sure why. Yet another mystery to solve, I guess.
2,230
@AlexCL posted it. I restored it because I love to restore old print information and other media. :giggle: I am glad I inspired you! :D👏
I wasn't chastising either of you. I was chastising myself for extending that topic. :) But if you find a way to extract the PICT files from the Snooper 2.0 app, please send me a PM! Makes no sense to me why opening the PICT resource is crashing every Mac emulator I've tried. Not just ResEdit, but Resourcerer too. Very curious!
Elemenoh
460
450
Bay Area
I'm in the process of troubleshooting a LaserWriter 12/640. The service manual refers to a EPOST (Extended Power-On Self Test) mode. This mode is initiated with a "printer rollback test plug" (P/N 922-1489). I went ahead and tried the loopback plug I built for Snooper and can confirm it works fine to put the printer into EPOST mode.
Now I just need to figure out how to repair the laser/scanner assembly. 🙃
lilliputian
277
123
Los Angeles, California, USA
Maybe CanOpener would work?
2,230
After reading your post today, I tried opening the PICT resource of the Snooper 2.0 app using ResEdit 2.3.1 on a real SE/30 (no accelerators) using both a BlueSCSI and a MacSD, running 7.5.5, 7.1 and 6.0.8; but in every case I get a BUS ERROR when I click the scroll bar's down-arrow 3 times. I find that very odd.
Next, I booted into System 7.1 and launched CanOpener 4 and selected the Snooper 2 app. In total, it extracted only the main splash screen picture and 4 icons. I did not find any of the motherboard images contained in the PICT resource.
So for now, I am dead in the water on this one. I would encourage someone out there following this to give it a try with Snooper 2.0 yourself, maybe on a Mac other than an SE/30 to see if you can extract the motherboard images from the PICT resource of the Snooper app.
Crutch
293
228
Chicago
I like a weird mystery so decided to take a look.
You can prevent ResEdit from trying to display thumbnails of the list of PICT resources (and therefore maybe crashing if there’s junk in there) by opening the “PICT” resource type icon while holding down the Shift key, or by typing Shift-Return. This gives the list at left, you can see “plus”, “classic”, etc. which I presume ought to be the PICTs for each bare logic board.
You can then open a PICT resource to look at the raw data by choosing “Open Template…” and leaving the default template type of “PICT” in place then hitting Return. That gives me, for example, the data on the right.
I can see immediately that this is not a normal PICT: the Rect is invalid (those coordinates are top, left, bottom, right, in that order … you can see the image is weirdly tall with bottom - top almost 8000 pixels, and the right is less than the left, which shouldn’t be possible).
You can do something similar in Resourcerer by clicking the PICT type name from the list, then pressing Cmd-1 to turn off “Show PICT Data” and then opening the resource by clicking “Data” instead of “Open”. This gives the error shown in the second snip below, confirming that these are not properly parsable sets of PICT opcodes.
My guess is these are actually bitmaps, or maybe portions of a valid PICT that Snooper stitches together on the fly to create those logic board images. I don’t think it will be possible to directly extract the images from these without some sort of processing.
I would suggest just using Cmd-Shift-3 to grab screenshots while running Snooper.
