I picked up a Power Macintosh 7100/80 AV with the AV video in/out card a few months ago. Last night I decided to tackle this behemoth. The logic board has 25x 47uf 16v caps, and one 100uf 6v cap. The video card has 13x 47uf 16v caps.
Overall not a bad nights work but quite overwhelming if you aren’t experienced in this work.
All of the caps are the bigger size so it’s not like soldering down those rice size caps as you find on an LC.
These logic boards have a different solder mask coating than many other Macs, and it’s similar to my Quadra 800 boards and many 6100/66 boards. It seems to clean up nicely and I did not notice any signs of trace corrosion from leaking caps.
The pads under each cap had a dry residue from leaking caps. I plan to attach some heat sinks to a lot of the chips to avoid any overheating.
