NeXT and BlueSCSI question
ScutBoy
351
Northfield, MN USA
I'm trying to build an image for NeXT black hardware on BlueSCSI. Latest firmware.
I've used both the NeXT tool to build disks as well as the image @Drake called out from Winworld that is said to work on BlueSCSI for NeXT.
The image is seen by the NeXT as a drive, but in both cases its seen as a read-only device like a CD-ROM. I've poked around a bit, any ideas on what I might be missing.
The original drive is still in the system, but I boot with
bsd(1,0,0)sdmach rootdev=sd1
and while the boot starts, it fails out early since it can't write anything to the disk.
ScutBoy
351
Northfield, MN USA
OK - so during this I had the original spinning disk in the machine (SCSI ID 1) while the BlueSCSI had a higher address (tried both 6 and 2).
The BlueSCSI was in an external enclosure. Once I disconnected the internal drive so the BlueSCSI was the only thing on the bus, then it came up read/write and booted as expected.
So, some kind of SCSI voodoo or who knows? Anyway, it now works as I expected and I don't need to listen to that screaming Seagate anymore!
647
Good to know if my old SCSI2SD ever dies. I bought it and struggled with it long before BlueSCSI was a thing, but will certainly be replacing it with a BlueSCSI if that time comes.
Drake
Emeritus Board Member
795
Sorry I didn't hop into thread until now. Glad the bluescsi is sorted. In my case when first troubleshooting my Next cube the original HDD seemingly crapped out immediately after building an image onto the bluescsi. That being said I was running both at the same time (the bluescsi was blank).
If you or anyone has a method of updating the Next image with more software and games please let me know/share. I haven't the chance to drag everything out again since repairing my slab.
Reactions: wottle
michaelengel
I remember researching the partitioning scheme and filesystem for the NeXT when trying looking at the Haiku port… The NetBSD sources are quite interesting in this regard. Oh, I extracted the info from the NeXTstep headers it seems. At one point I wanted to add support for those in Linux tools like parted and testdisk, you may want to have a try.
Oh, a Haiku port to black hardware? That would be nice to have :).
The NeXT Plan 9 port (kernel source in sys/src/9/next/ in the second edition sources) as well as the previous emulator sources are also helpful for bare-metal programming.
I started to play around with NeXT bare metal programming and wrote a little demo – so far only tested in previous. If you're interested, feel free to take a look at my github repo.
Reactions: mmu_man
JdM74
41
44
Georgetown TX
Greetings. If you're a member of nextcomputers.org, check out the post in the NeXT Black Hardware section, "BlueSCSI Settings". This will give some helpful setup tips when getting started.
Reactions: mmu_man
