SCSI Zip Drives?
rjkucia
233
81
Madison, Wisconsin, USA
I recently got a USB Zip drive that came along with a bunch of other stuff, so I thought getting a SCSI one would be a good way to moving files between my SE/30 and modern machines. Unfortunately, it looks like SCSI Zip drives are relatively rare (at least to find working models). What's been confusing me is that there are a ton of parallel models that advertise themselves as being SCSI. Is this just eBay sellers mixing up terms, or do parallel models actually work over SCSI?
2,347
They usually are mistaken - You'll need to see a photo of the back (with a SCSI id selector to be 100% sure afaik). Best luck I've had is a local pickup, there's usually one every few months. And yes they are handy to use.
Reactions: rjkucia
There is one eBay listing that correctly identifies as SCSI Zip Drive:
This SCSI ID switch in between the connectors on the back is how you know:
And on the bottom of the SCSI Zip drive explains that as well:
Reactions: rjkucia
Oh, @rjkucia, this is a good deal as it is listed as used functional and comes with power brick and cable. Seller accepts returns.
You can see about getting $20 off. :)
Reactions: rjkucia
Patrick
435
i purchase a newer one that claims can do both SCSI and parallel. i haven't tested it out yet.
i just thought it was neat.
