2.5" -> 3.5" SCSI adapter
Branchus
529
Does anyone know if a 2.5" to 3.5" adapter exists that would allow me to connect a PowerBook SCSI drive to a desktop vintage Mac?
I would hope the process isn't too complicated.
Thanks in advance,
Bruce
max1zzz
680
They do, I have one around here somewhere
It'll probably be quite difficult to source one now, given they would have been pretty niche even back in the day and 2.5" scsi drives are all but extinct now
It wouldn't be too difficult to reproduce though given it's just a straight through passive adapter
If your really desperate your welcome to mind if I can find where the damn thing is (Not sure waht shipping form the UK to Australia would be though!)
Branchus
529
At the very least I'd love to see some good quality photos of it to see if I can make my own.
Many thanks,
Bruce
Branchus
529
Thank you once again @Androda! The PCB arrived today, I put it together and it's exactly what I was after. I decided to attach a whip cable with a Molex connector instead of the Berg as it suits my needs better.
408
199
I'm a little late to the party, but I picked up one of these earlier in the year and it works as advertised. Not as much geek cred as building a PCB yourself, of course.
I just bought one of those. I saw an article that linked to the seller somewhere.
The thing that puzzles me is that the 2.5" connector is 50 pins. Isn't the connector/cable on the 2.5" drive 40 pins?
Does the adapter cover the SCSI ID pins and then move that functionality to the jumpers on the adapter?
Does anyone have a datasheet for a 2.5" narrow SCSI drive? Or an old dead one they don't want any more? I want the physical dimensions.
This Does Not Compute
Emeritus Board Member
375
537
The adapter provides power to the 2.5" drive, and does indeed "move" the SCSI ID jumpers to the adapter's PCB. Here's a shot of the adapter connected to a drive; the SCSI jumpers are on the right and the power input is on the left.
Reactions: trag and Branchus
Androda
542
608
USA, Western
androda.work
SCSI only "needs" 19 pins. 18 for data and control lines, plus termination power. The 50 pin scsi connector is mostly ground lines.
The 40 pin powerbook scsi connector has three power sources: motor power, drive logic power, and termination power. That's 5 pins used, leaving 34 (one pin missing to ensure orientation) for a pretty even split between 18 necessary scsi signals and grounds.
Reactions: Branchus
alxlab
324
www.alxlab.com
Here's another 2.5" to 3.5" adapter that was created back in in the day:
These came with 2.5" IDE to 2.5" SCSI adapters as well. The model is Winstation Systems 25HD-02:
Was planning to use it in my LC 520 but then I found out the hard drive connector of the LC didn't fit in the adapter. It's on my todo list to make another adapter that will work.
Reactions: ApfelKlassik.de
Branchus
529
With the benefit of hindsight, a little adapter like this would have been perfect, but having gone down the path of assembling my own, I do quite like having the ability to connect two drives to the one adapter.
408
199
Generally, one SCSI jumper represents '1', one represent '2' and one represents '4'. The SCSI ID is the sum of the jumpered values. For none jumpered, one gets '0'.
