Time for an Athlon-XP Build - Project Middlesex (Now with pretty pictures!)
Almost 20 years ago (jesus, that hurts to say now), I was nearly ready to begin my computing course at Middlesex University in North London.
Disappointment of the course and ineptitude of the University aside, I had put together a damn good rig to handle almost everything that you could throw at it (in a purely gaming context, of course).
Naturally, over time i upgraded to an Athlon 64 (by the end of my 1st year), but I wanted to try and rebuild the machine I have the most fond memories of.
To that end, I have acquired the following.
CPU: Athlon XP-2500+ (AXDA2500DKV4D, 333MHz FSB)
CPU Cooler: AMD Branded AVC AV-112C86 - Copper Core Heatsink & Fan (Originally bundled with the Athlon XP-3200+)
Memory: 1GB GeIL (2x512MB, PC3200, 2.5-6-6-3 timing)
Motherboard: MSI K7N2 Delta-ILSR
Graphics Card: ATi Radeon X800 XT (made by Sapphire)
Rather than risk it all, i'll be using a modern 400w PSU and i'm going to use a small 128GB SATA SSD because i'm not going to mess with trying to find working, small capacity SATA hard disks.
Now I just need an era-specific case, i'd love to find the Jeantech Butterfly case, which opens up much like a Powermac G4. I'm nearly there, as i have a few leads on one of those cases, most recently in lithuania (shipping will be a *****), with a bit of luck, I can finally throw all of it together and then I can get it loaded up with Windows XP SP3 and sling Doom 3, Unreal Tournament 2004 and Far Cry on it :cool:
After having a look at the board, this is definitely not in bad shape, it's clean, not a spot of dust and looks to have seen very little usage. However, as it's 20 years old, the caps WILL need to be replaced.
The caps on the board currently are Rubycon caps which are...meh, i guess?
At least one has blown, and is sitting at an acute angle, poised to take off into orbit at the first sign of powering on as if to say 'i must go, my people need me'.
To rectify this, i've been and measured the caps. I'm able to replace the MOSFET caps with good quality polymer caps - @JDW take note ;)
The rest however, aren't available, so i've gone with Panasonic/Nichicon electrolytics instead, all 105*c rated like the originals, and all low or ultra low ESR, so this board should be more than stable feeding that XP-2500+. Not too expensive either - £25.85 including shipping from mouser.
RetroTheory
90
161
Sold a lot of pcs with this case back in the day, I knew I had at least 1 hanging around , I think I have the bones of a second.
Yours for postage if you want. It would go though normal post as none of the couriers I use will send to uk.
These pictures were taken today.
Oh, wow! Yes! Dm me and let's get this thing built!!
Thanks to @RetroTheory , the case has arrived! I've not unpacked it yet, i've had 0 time to deal with any projects lately, I'll need to recap the Motherboard before I go ahead with the build, just to make sure the board I want to put in there actually works! 😅
Reactions: RetroTheory and JDW
QuicksilverAUS
12
Brisbane
Hi Kai mate ive got a spare shappire x1600 pro agp (128bit ddr3 512mb) floating around here doing nothing happy to send to you'r way , nice upgrade from that x800xt , pm me with some contact details ill slide it your way mate :)
croissantking
138
64
Not sure if interesting but this summer I restored my PC built around an Athlon XP-M 2500+ CPU. It's actually the same PC I built back in 2003 and I've kept it all this time - although it has evolved from original spec. The Asus A7N8X Deluxe 2.0 I've now got in there is the fourth board that's gone through the build, all the others failed (Asus A7V8X, Asus A7N8X-E Deluxe, Asus A7N8X-X).
Stinkerton18
110
96
Mmmm nForce2 goodness. They were great for their time. I'm sure you've already checked it in the motherboard manual but make sure you have your RAM in the right slots so you get the dual channel speeds.
You planning to do dual monitor with the chipset video?
Wasn't planning on doing dual monitor - Kinda want to pair it with the Dell Trinitron display i pulled out of the skip all those years ago, but finding CRT's in the 2020's is like searching for gold dust.
I remember the nForce 2 RAM bank shenanigans - i literally just need a PSU and to actually recap the board - i just lack the space for it right now.
Oh... Well now I have a dilemma - as in my second semester of my first year of Uni, I upgraded to an Athlon 64...and later, an Opteron 146...then an Opteron 170.
I came across this Asus A8N board (nForce 4) with PCIe support. I also happen to still have my XFX 7600GT from way back then, too.
The only issue with the board was the cpu heatsink bracket was snapped.
No worries - 3D printing to the rescue!
Now, which version of Project Middlesex should I build?
Stinkerton18
110
96
It's odd that the nforce4 board has a PCIe 4x lane but with a clip for a 16x card. Why not just use a 16x slot? #WeirdOEMDecisons
My med-clouded humble opinion is go with the Opteron 170 for dual core and better IPC than the original Athlon 64s.
