Floppy drive head ribbon cable broken
darvil
Hello all, recently I got my hands on a beautiful Mac SE/30, and I've been giving some maintenance to it. Unfortunately the floppy drive didn't seem to work. After looking at it, i found out that the ribbon cable of the bottom head was broken, as seen in this image:
I was wondering if anyone would have a suggestion for this kind of problem. For now I am going to attempt to solder them back together, but I am not sure if I will be able to with my current equipment, since this seems to be way more finnicky than soldering some board components 😅.
If I'm not able to fix it, would I be able to find some replacement? Are heads of the same type a more common piece among different models of floppy drives, or does this floppy reader only work with this specific heads? My experience with this devices isn't very broad, sorry.
Thank you.
Nov 4, 2021
126
99
Tucson, AZ
Congratulations, you have a super rare after market 400k drive conversion! :)
My inclination for a hail Mary repair would be to butt the pieces back together and bridge the cut with copper tape, and then try and cut the gap between the traces out of the tape without making things worse.
There's also Z-tape which has been used for connecting LCD screens in calculators because it only conducts along 1 orientation. One long strip goes between the whole row of pins on the LCD glass and the PCB and instead of shorting out everything and letting the magic smoke out it connects the traces on the PCB to the pads on the LCD. Something similar might work for the flex cables if you can scrap off a little plastic insulation and squeeze them together somehow without interfering with the moving parts. Z-tape might distort the signal too much to be usable for a disk head though.
Maybe someone rescued a pair of heads from a drive where all of the moving parts had rusted into a solid block, that'd probably be best.
2,000
Do you have the exact model number of this drive? I have a stack of bad floppy drives about 5ft tall, I might be able to find one with that cable/mechanism intact. (free for shipping costs)
darvil
For now I will attempt to bridge the gap between the two pieces of ribbon cable with some copper wires and some good hand pulse. Hopes aren't very high though! But it's worth trying.
Yeah, it seems to be a model MP-F75W-01G, or at least that's what it says on the sticker at the bottom. (On top of the disk rotation motor), as seen here:
Would be awesome if you happened to have one lying around! Thanks.
I will give an update after I (hopefully) finish the repair.
darvil
Update here! :) As expected, that was a failure. There's still some hope, though; I may try Lumines' suggestion of using copper tape, after I get some. Thanks again for the help!
If in the end I'm not able to get it working, that is fine. I'm getting a BlueSCSI in a few days, and I'm very excited for that!
darvil
Hello, after investigating a bit further, I have found out here that three floppy drive models seem to be perfectly interchangeable. Those being:
  • MP-F75W-01G (Mine)
  • MP-F75W-11G
  • MP-F75W-12G
This information may help on finding broken drives :)
Seems like the 11G model seems to be a bit more common.
Thanks and sorry for creating more activity on this post with updates.
Reactions: eric
darvil
Hello! Here goes an update after a long while;
I was able to find a MP-F75W-11G on eBay for cheap. It was quite rusty but luckily the head was intact but I didn't even think it twice to buy it to test for luck...
Did the replacement of the head and... It works perfectly! It is able to read and write from floppies without any issue.
In a case it could be useful for someone, I'll leave two little notes:
When lubing the drive after cleanup, make sure you do not lube this metallic pieces here:
Lubing this will make the pieces slide slower, preventing the drive from keeping itself in the "empty" state. There's a little knob that latches on the assembly when the disk is ejected. If lubed, It won't easily latch, not letting you get the disk out!
If the disk is not pulled in by itself, make sure the little metallic pull knob is properly (vertically) aligned with the disk:
That's it! Thank you all for the input on this thread.
Reactions: S. Pupp
