MFM Floppy Drives?
Ron's Computer Videos
214
307
Has anyone here ever encountered a PC floppy drive on a Macintosh clone? The Tarzana motherboard design did make accommodations for a MFM style floppy drive, but I've yet to find photos of a board with those components installed.
Anyone seen one?
Reactions: Patrick and eric
Anden Selmani
24
Albania
Technote for the LPX-40 motherboard
I don't think this was ever used on a shipping product. It would have greatly limited disk compatibility which probably would have not been seen in a positive light.
That being said, browsing everymac shows about a billion Mac Clones where the only graphic evidence of existence is a tiny thumbnail from the 90s.
There's probably a ton of clones that were scrapped because they looked like boring PC stuff.
The Starmax that shipped had a bezel without a cutout for the eject button.
Even the various prototype CHRP Macs seemed to use a Mac/GCR floppy.
hey look, MacOS 7.6 for CHRP. one of two known copies of CHRP MacOS... neither archived
Unreleased CHRP StarMax
Another Motorola Viper CHRP prototype
Supposedly the Gossamer G3 logic board (as seen on the 'beige' G3s) also has a header for a PC-style MFM floppy drive... under the Mac floppy socket. I haven't confirmed this though, nor have I seen any pictures or evidence that it's ever been tested.
214
307
A "Mac" with ISA slots is the real story here ;)
Thank you for responding with all the great into - especially that dev note about the 4400!
Reactions: eric
max1zzz
673
I'm about 90% sure the board in my beige DT has a MFM header on it. Maybe i'll try desoldeirng the Apple / GCR header and installing a MFM one since the G3 is really a parts mac anyway
VicNor
Sweden
What?! :O Pics or it didn't happen
556
Sounds interesting... let us know how it goes and I may try to duplicate. My G3 DT currently has a 450MHz G4 in it, overclocked to 533MHz.
306
123
Open Firmware does contain code for MFM drives.
Open Firmware, 2.0.2 for PM 4400 and 7220 can choose between a MFMfloppy device and a swim3 device depending on some value read from a board register at offset 1a000 of OHare. There's a Open Firmware driver for swim3 but not MFMfloppy.
In Open Firmware 2.0a9 and 2.3 for Power Express, the device name is fdc instead of MFMfloppy and it has a Open Firmware driver.
2.0f1 and 2.4 (for Beige G3) is similar. The value that chooses which type of drive is connected is a register in Heathrow at offset 0x38 (feature control register bit 27 = MIO_OH_FC_USE_MFDC).
The name of the classic Mac OS DRVR is ".MFMFloppy" in all the above cases but also in other Old World Macs after Open Firmware 2.0 (PowerBook 3400c, PowerBook G3 Kanga, PowerBook G3 Wallstreet, PowerBook G3 Wallstreet PDQ).
New World Macs may have fdc but it's type is swim3.
Reactions: Mac84
croissantking
115
56
I desoldered the Mac floppy port and fitted a PC floppy port onto my Beige G3. However I can't get a PC drive to work – it's not detected and doesn't do anything.
  • Sad
Reactions: phunguss
misterg33
66
17
i'd recommend looking at the PowerMac 4400 developer documenation (and an actual 4400 if you have one). The whole thing is like a CHRP proof of concept. If you're connecting a manual eject floppy drive, it's probably your best bet for finding a Mac that supports it. While the dev dock says it's not supported, it also says there's a connector for it. Didn't someone unearth the CHRP version of MacOS recently? Maybe the software support/extension/whatever is in there.
306
123
There are unpopulated ICs on the board near the connector. I feel like that's somehow related.View attachment 27853
U44 is not mentioned in the Beige G3 schematics.
https://www.macdat.net/repair/apple_schematics.html
The schematics do have the GCR and MFM slots. The MFM slot connects mostly directly to Heathrow so maybe U44 doesn't have anything to do with it?
There's a couple resisters R340 and R341 marked "NO STUFF" on the schematic. Are they not populated on the motherboard?
306
123
Coincidentally, the Power Mac 4400 schematics do have a U44 connected to MFM. The 4400 uses OHare as the mac-io controller. I suppose the U44 MFM controller was moved into Heathrow and Paddington and those newer chips added the MFM feature control bits?
214
307
Sorry. I should have clarified. The board in my photo is from a 4400... which is basically the board most of the clone machines. Save a buck however you can on the clones, right?
I seem to remember reading something about the MFM prototypes not being about to read 800K floppies?
306
123
In that case, I wonder if it means anything that the Beige G3 doesn't have a U44? The schematic has 23 components with a U prefix numbered 1 to 47. Why does it skip some numbers?
