Mac Plus J8 part number?
Ron's Computer Videos
236
319
Does anyone happen to know the manufacturer and part number for the J8 connector on the Macintosh Plus motherboard?
Thank you!
Daniel Hansen
181
145
according to an old website, the AT power connector part number is MOLEX 15-48-0106 X2
Looks like that part number suggests a 6 position header, J8 is 11 position. I don't know the original manufacturer or part number... if you don't have a parts board to snag one from, something like the Molex 0022112112 - a single-wall friction lock 11-position header - looks like it would work. 2.54mm spacing though... if 3.96mm pin spacing, then the Molex 0026604110.
Mu0n
711
676
Quebec
2,232
theducks
7
14
Here in Australia we have an electronics store called Altronics, which sells Oupin 4771 3.96mm connectors - https://www.oupiin.com/product_ii.php?c2=135 - which are compatible with the original connectors. 3.96mm is uncommon spacing, so checking the usual suspects, Molex KK 396 has a similar "wave" board side connector. I have some Molex KK harnesses on the way from digikey, and will update if I'm wrong (But I'm pretty sure I'm not)
236
319
theducks
7
14
If you have a direct link to this "KK396" part at either Mouser or Digikey, please post it.
It would be this one - https://www.digikey.com.au/en/products/detail/molex/0026604110/193997 for the board side and this one for the wire side - https://www.digikey.com.au/en/products/detail/molex/0009503111/26471
I'll update with photos when my order arrives. I'm also getting some of these - https://www.digikey.com.au/en/products/detail/molex/2196641103/16106137 - and will move the wires across into the 11P connector
(Also, I didn't know you made that little board! That's cool!)
Reactions: trag
236
319
For the record, the part you list here is seemingly the exact same part I listed above... and it's $1.20 cheaper per unit on Mouser. So if you're buying in quantity, that might be a consideration.
Reactions: JDW and trag
