What’s faster RAM Doubler or BlueSCSI + Virtual Memory
Sideburn
267
102
California
Curious what would be faster to increase your physical ram from 8 MB to 16 MB using either 32 but addressing and virtual memory or using Connectix RAM doubler.
I’m sure a BlueSCSI is faster than a physical HD but is it as fast as SSD and how much slower is it than physical RAM?
Connectix RAM doubler uses compression so that’ll eat up cpu cycles.
Wondering which method would be fastest.
What do you think?
Androda
523
581
USA, Western
androda.work
My initial reaction is that RAM Doubler would be faster overall. Compression uses CPU cycles, yes, but those CPU cycles are likely still dramatically faster than reaching all the way out to a hard drive. Even if that hard drive is an SSD.
Sideburn
267
102
California
Ahh I didn’t think about that. I’ve been experimenting with it. Seems to work ok as a solution until you come out with a PowerBook 100 series ram expansion 😜.
1,899
IIRC most ram around this era is 70-100ns? BlueSCSI seek is ~1ms. 1ms is 1000000ns right? There's an old analogy (cant remember exactly) that L1 cache is grabbing something off your desk, L2 is going to the mailbox, RAM is like going to the store, disk is like flying to another city :) (something like that anyways)
Also some apps do require physical RAM and wont launch if they detect they're using virtual memory.
Reactions: JDW and Yoda
1,943
I concur with Eric. Now that I have a IIci and have cards installed, I am seeing a lot of warnings in the documentation for add-ons about having Virtual Memory switched on. Some things either won't work with Virtual Memory switched on at all, or acceleration will be lost.
