PowerMac 8100 Booting issues
nottomhanks
103
Hello there!
I just picked up an 8100/100, and it chimes when you boot, (actually it powers up when you plug the IEC cable in, which is interesting).
Do you have to have the HPV video connector to see video, or will it jump to the next available video card?
I tried resetting the PRAM, but it wouldn't work.
Please help if you can.
Craig
Mr. Fahrenheit
232
The 6100, 7100, and 8100 series require a good PRAM battery on-board to display any video.
The instant power-on you experienced could be the power button on the rear rotated into the “always on” position.
nottomhanks
103
Ah. Those are helpful tips. Will the video show up on the DB 15 connectors on the Nubus Video card, or will it try to go to the HPV first??
RetroTheory
90
161
The mac has sense pins on its monitor connections, it knows there is nothing there so will initialise nubus if monitors is connected there. HPV is not required.
Reactions: nottomhanks
JustG
65
17
California
I may be incorrect but I remember reading somewhere that 7100 and 8100 systems need to have a card in the PDS slot otherwise the computer may not boot or can crash.
Reactions: RetroTheory
RetroTheory
90
161
You are quite right, That's what it says in the Service source, i have not encountered an issue in real live though. Currently running my 8100/100 without a video card or terminator, that the link above shows my one going to flashing floppy as such.
nottomhanks
103
The weird thing about this machine is that the bezel says 8100/100 but the logic board says “Flagship 110 Mhz”. Plus it has the NewerTech G3/300 card installed. Is this a rare logic board or something?
bakkus
131
91
The NewerTech is a cool addon, but could be one source of issues.
Did you try booting with the G3 removed?
There was a 110MHz model released late 1994.
nottomhanks
103
Just following up on this TWO YEARS LATER. I had my friend @ComputerCompulsive take a look at this over the past few weeks, and he figured out that the L2 Cache was bad, and it wouldn't post if it was installed. He removed it, and then got it to boot. I was over there this morning and we did some extensive testing with two logic boards, two G3 accelerators, AND two HPV cards!! Will post YouTube links soon.
  • 8100:110 G3 300 Intro.MOV
Reactions: ComputerCompulsive
Nov 27, 2022
114
I did a recap too ;) should be good for a while
