Hacking FinderHack: CMD-DEL for System 7.1
2,223
I wonder if it is the application launching, or the control panel.
More than 50% of that 4-5 seconds is the AppleScript "application" launching.
Do you know if the bulk of that [memory usage] is EZ-Keys? Or AppleScript.
It's almost all AppleScript.
If a knowledgeable person were to write a one-trick pony Extension in Assembly language that would put selected items into the Trash when CMD-DEL is pressed, that would likely be the smallest and fastest solution. :) But patience is a virtue, and for now, the AppleScript 1.1 + EZ-Keys method does work. (y)
phipli
259
I'm not sure that much effort is worth it for saving a couple of seconds, you're asking a lot of someone - you're potentially asking someone to patch the OS. Plus something probably already exists.
