Getting MIDI to Work on an OASys IPAD...
jdmcs
TinkerDifferent Board DoP&G
112
75
Central Virginia
Fellow Tinkerers, I have bought one of those DOOM-playing "bump bars". And not content to simply playing DOOM, I want to get MIDI out to work.
Since the bump bar was never designed for MIDI out, I have a MIDICloud RS-232 from Serdashop so that I can attempt to use one of the serial ports for MIDI out.
And I've already run into the first problem: At least with MS-DOS 6.22, I can't get EMM386 or QEMM to work properly - one of these extended memory managers is required to run SoftMPU, which itself (or a similar program) is required to redirect MIDI output on port 330 to a serial port.
No matter which settings I tried, if I let EMM386/QEMM load, then as soon as autoexec.bat starts to run, I get the error Invalid Command Interpreter. It would seem as if these products are potentially stomping on memory used by something else...
Has anyone attempted what I am now attempting? And does anyone have any suggestions to try in order to get EMM386 or QEMM to load properly?
Note: I am not opposed to trying FreeDOS. However, I wasn't able to get a FreeDOS installer written onto media that the iPAD would then boot... I only used MS-DOS 6.22 for my first attempt because I already had it installed on a CF card and the IPAD was OK with booting from it using a CF to USB adapter.
Mu0n
648
605
Quebec
Here are my config.sys settings for when I need to use expanded memory so I can run SoftMPU.
DEVICE=C:\DOS\HIMEMSYS /testmem:off DEVICEHIGH=C:\DOS\EMM386.EXE 2048 AUTO
(you can change the number 2048 to your needs - some rare programs complain when I had too much allocated RAM from my 256 mb of available RAM in my weecee).
the same config file also runs well on my 486 with 32 mb of RAM.
jdmcs
112
75
Central Virginia
So I forgot to try to load EMM386 high, but the parameters “2048 AUTO” only changed the symptoms slightly. DOS 6.22 was able to finish booting, but I started getting general failed errors on C: after a few disk accesses…
It’s not the disk (it doesn’t happen when I don’t load EMM386). I’m wondering if it’s one of the following:
  • An incompatibility between DOS 6.22 and something I can’t change about this board: the SoC, the BIOS (it’s a SeaBIOS), and/or the amount of system RAM (128MB).
  • An incompatibility between DOS 6.22 and USB booting the system. (I can try an SD card but only if I find a reliable way to install OS images into it).
  • Bad RAM (booting a memory test program could prove problematic).
I’m willing to try FreeDOS and a newer version of MS-DOS, but I’ll need to create the images off-device - the iPAD can’t boot from a USB floppy drive, and I’m not optimistic that CD but is supported.
jdmcs
112
75
Central Virginia
can you paste everything in your autoexec.bat and your config.sys files?
The current CONFIG.SYS is as follows:
DEVICE=C:\DOS\HIMEM.SYS /TESTMEM:OFF
DOS=HIGH
FILES=30
And the current AUTOEXEC.BAT file is a blank file.
