Apple III garbage on screen at startup
735
I just picked up an Apple III locally and it came with a ProFile 5MB Drive (unfortunately no Profile card in the machine), two Apple /// Monitors, and the external floppy drive. I need to replace the RIFA caps as the big ones are cracked significantly.
However, I decided to start it up in the garage to get an idea of if it could boot. I know nothing about the III, other than that they were short lived and had thermal issues. When I started it up, the good news is I do get a picture out and the display on the /// Monitor looks pretty good. (The other /// Monitor has a tear in the anti-glare screen, so I need to disassemble it and remove. the screen). Unfortunately, the screen displays two screens of gibberish.
First, this, with a square in the bottom right that is changing:
Then I get a second screen that looks like this:
The screen goes black and then it repeats. I didn't let it go too long, because the RIFA caps looked like this (Yes, it appears there is a hole in one of them):
The remind me of the Apple II when it has memory chip issues. So, I decided to remove the RAM card, give everything a nice wipe down, remove every RAM chip, spray some DeOxit on the sockets, and reinsert them in a different order. I also removed and put DeOxit on the CPU socket. Unfortunately, the same result.
While I wait for my caps for the PSU, any thoughts on where I can start troubleshooting / ordering some replacement chips. Is it possible the CPU is bad? Is the 6502 available to buy if it was?
735
Just a quick update that may give some more idea of what's happening: when I do a Open Apple-Control-Reset, the screen resets and it appears the floppy doesn't try to reload, but the interesting thing is when I start typing on the keyboard, I do see the pattern change, which makes me believe some boot up is happening, but maybe the video circuit is bad. Not sure if that helps, but any advice would be appreciated!
735
OK, so I decided the RIFA caps are probably not in good shape to continue using. I removed them and tested and the .22uF one appears to be shot. Would that cause issue with the PSU voltage that could cause problems with the video output. I suspect the square in the bottom right that is changing is actually the RAM test showing possibly a bunch of bad RAM chips, but the video output is rotated or flipped.
Also, I removed, applied DeOxit, and reseated every socketed chip (and cleaned up a few of the chips that had oxidation or corrosion on the legs (surprisingly not many). Still the same result. Will likely wait until I can get the PSU recapped with new RIFAs and some of the caps (I got a kit from Joes Computer Museum). In the meantime, anyone have an idea why the video is corrupted like it is?
Also, is there a good way to monitor the voltages under load when the machine is running (like the floppy port on classic Macs)?
573
www.floodgap.com
I don't have much insight here for you but my Apple III did something similar and I put it in storage to ponder how to fix it. I don't remember the caps looking as bad as that but I'll check them again next time I'm in that unit.
Reactions: wottle
735
It seems like Joe's Computer Museum is trying to specialize in the III. I ordered a cap kit, but I'm wondering if I should have added a video ROM to my order in case that is the source of my video problems.
Reactions: ClassicHasClass
573
www.floodgap.com
The video ROM might help, since you don't have anything recognizeable as characters in those pictures (the A3 should come up in text mode). Mine had properly formed characters; the screen was just garbage.
Reactions: wottle
735
OK, so I did confirm the III is booting. I was able to make an ADTPro SOS disk from my Apple IIc+ and booted the Apple III with it in the drive. And, I certainly can tell it is booting SOS and launching ADTPro.
I can interact with the app with the arrows and it is beeping at me, so I'm encouraged by that. I'm hoping it is a bad video ROM, but that's pure speculation at this point. But it gives me hope that there's not something horribly wrong with this machine. When I get my order from Joes Computer Museum, I'll swap it out and see if things improve!
Also, I gave the case a good cleaning and retrobrighted the beige bits. It's going to look good!
735
So I used ADTPro to make an Apple /// Diagnostics disk. When it started up, I hit enter (I assume it's the first option to run the tests?). And I get this screen:
So even when not in text mode, the image is not being draw correctly. It seems as though the image is broken up into parts, and the parts are drawn on the screen in the wrong place, sometimes in the wrong location. I have some replacement ICs coming, as well as a Video Controller ROM, so hopefully I'll be able to fix that is causing this.
Reactions: nottomhanks
735
Can you create Apple III floppies with the Disk II/DuoDisk?
Yeah. I used ADTPro on my Apple IIc+ with a Disk II attached. I wasn't sure if it was worked, but figured it was worth a try. Seems to work fine - I created the SOS ADTPro disk, as well as the Apple III Diagnostics disk and an Apple III confidence disk.
Given the messed up video output, and not knowing how those disks actually work, I took a chance that the first option I could choose on the Diagnostics disk would do something interesting.
735
One other thing I found. I replaced the most of the ICs in the video schematics and god no change. However, I noticed on mine that the chip at H8 was labeled on the PCB as an LS04, but the schematic and the chip in my machine was an LS14. I replaced it with an LS14, but was wondering what others' boards have marked, and what is installed.
735
So, I got a replacement video controller ROM from JCM and no change in behavior. This may be beyond my equipment and skill to continue troubleshooting. I've not replaced nearly everything in the video schematics diagram. I suspect maybe the video I/O is working well, but the instructions on what is to be drawn is where the problem lies. Unfortunately, my approach of replacing more and more items is getting expensive... And it doesn't address potential connection problems between the components. I'll probably see if I can better study and try to understand how the image is displayed in the Apple III to see if there's more I can troubleshoot.
It definitely is so much easier when you have a spare, working machine to help diagnosing problems.
