@Zhinü I got the components to make the cable. However, I have a Lisa 2/10 which doesn't have a built in parallel port. It does have a Parallel power card, but I've never used it. I did try to use the external version with the cable I created, and I was able to get the selector to show up and give me a choice of drive images, but when I tried to boot either LisaOS or Macworks, it would not boot. I know the device is good, because if I power it externally and plug it into the internal parallel connector for the widget, it boots into both OSes just fine.
So, either the parallel card is bad, or my cables. I made the cables to mirror what the creator of the ESProfile shows on GitHub, but I could have done something wrong. I suspect maybe it is the parallel card, but I don't have any way to confirm. So, if you want an external one with cable, just know it would only be partially tested.
DM me and we can figure out what you want to order. Also do you have SD cards and know how to throw Lisa drive images on them, along with the selector drive image? I can provide instructions. I have some microSD cards, but they would also be extra.
Thanks!
