Can You Put a White Phosphor CRT into an IBM 5155 (Portable Personal PC)?
jdmcs
TinkerDifferent Board President
135
108
Central Virginia
I am having trouble finding technical documentation on the IBM Portable Personal Computer 5155 (which I'm going to simply refer to as the 5155 from here on out) in regards to the voltages that the analog board can output to the CRT. And from seeing Adrian Black try to repair a terminal recently, I learned that some CRTs require different voltages than others. (I, too, had thought that all monochrome CRTs used roughly the same voltage).
I also have a 5155 with a broken CRT on the way to me. It seems like the easiest repair would be to do a tube swap. While I have been unsuccessful at finding an amber CRT (much less a Zenith CRT like IBM used), Macintosh CRTs are readily available. And while it seems anathema to put a Macintosh CRT in a PC, that's better than having no display at all. (Yeah, I know I could plug in an external monitor, but if I'm lugging my 5155 around, I don't want to have to lug a monitor around, too.)
Which leads to my question: can you put a white phosphor CRT into a 5155 and it actually work? Better yet, has anyone done it?
Reactions: phunguss and JDW
Volvo242GT
403
236
Currently Duvall, WA
As long as the power requirements are the same, and the signal is compatible, I wouldn't see any reason why not. Remember, Apple did offer the monitor /// in both a greyscale version and the more common green phosphor version.
RetroTheory
90
161
This is my tube swap between a mac and a 5155 monitor chassis , as long as crt band mount is the same you should have no issues
2,224
@RetroTheory
I certainly don't mean to detract from the main point of this thread, but in regards to your photo, it looks almost like you have that Mac in "dark mode." How did you accomplish that? It's pretty stunning.
And what interface are you using for the naked CRT attached to your Apple //c?
RetroTheory
90
161
@RetroTheory
The naked CRT is the CRT module for the IBM 5155 , but all it needs is 12V and an ntsc composite video signal.
The video is inverted with CloseView , with magnification turned off , but leaves a tell-tale zoom box see bottom right , its also a little slow.
There is an invert video program , I have that running on the IIci here running in 1bit , no performance hit.
and I wrote a little program to un-invert the corners so they remain black
The SE30 is currently running an SE board and invert video program wouldn't work, so I used CloseView. I think invert video program will run on a real SE30 just have not tried it yet. The IIci is using a color monitor running in B&W 1bit, but externally RGB are mixed to give amber effect.
Special treat
359
137
So the IBM 5155 has an amber CRT for displaying NTSC but it works for non-NTSC in a SE or SE30 and the SE30's CRT can do NTSC using the 5155 CRT module (which is the circuit that controls the CRT and not the CRT itself).
That means there's no real difference between a CRT for composite and non-composite video?
Regarding the InvertVideo app, why wouldn't it work with emulators? Doesn't it just change the color palette?
Reactions: Callan and JDW
723
@RetroTheory , I have an IBM 5155 on the way and would love to swap the CRT into the one of my SE/30s. Do you have any details on the procedure? Do you keep the yoke with the CRT tube and re-wire to the analog board? Remove the yoke from the Mac CRT and install it on the 5150? Any advice you can provide would be helpful.
RetroTheory
90
161
5155 monitor system, 12v composite video input
I took the yokes off . and kept the mac yoke with the Mac.
The 5155 tube has the anode cap on the opposite site with respect to the end connector.
I had to extend the wires to rotate the board so it would fit with the anode cap in the same location.
Kept the mac open for picture adjustment
jdmcs
135
108
Central Virginia
I'm glad I found an amber CRT for my 5155 by means of a parts 5155: while the white phosphor CRT should work, it would likely encounter the same challenges as putting the amber CRT into a Mac.
However, there's always the matter of that parts 5155, if I solve the case challenges (it looks like the Hulk Hulk-handled the metal chassis, and the drive cage plastic has been cut away on one side)... maybe there's still the chance that I'll try a white phosphor CRT in it if I don't find a way to connect an LCD panel to the composite output first.
2,224
Beyond the novelty of having an Amber CRT inside a compact Mac, how do you folks like them?
Would you describe the picture as being "easier on the eyes" or "just different"?
723
OK, I just went through the process and am happy with the results. I'm not using my MacEffects SE/30 super regularly and it clearly isn't my "true to the time period" machine. Here's the results, and I'll share my experience with the switch. after.
So, my plan was to do a "swap", but I wanted to keep my SE/30 CRT with the original case, just in case I wanted to fully restore it to a stock machine later. But I did have a Mac Plus with a bad analog board or PSU, that had a nice looking CRT (no burn in). Removing the CRTs went pretty smoothly, thanks to. good disassembly videos for the 5155. However, you can tell IBM at the time did not have the attention to detail that Apple had - they used so many different screw head types in the same machine, I'd hate to have been a IBM repair tech working on these back in the day.
Once I got the CRTs extracted, I was able to break the yoke's free pretty easily. As @RetroTheory says, the way for this to work is to keep the yoke with the machine, and swap out just the CRT tube itself. However, after getting the shielding installed and the CRT back in the 5155, I found something that others may want to know. The pins on the neck of the Mac Plus CRT were too thick to allow the neck board to be attached. I was applying as much force as I felt comfortable doing and it did not want to go in. I didn't want to risk breaking the neck of the nipple and ruining the CRT
However, I did have a Mac SE for sale that that I figure I could check. It does appear the pins are a bit smaller on the SE's CRT. Before reassably, I did test the neck board and it went on with a bit of friction, but not a ton of force was needed. So, I'm not sure if all Plus CRTs have thicker neck pins, but maybe try to use SE or SE/30 CRTs if you want to do a swap and put the Mac CRT into the 5155 like I did.
Another item of note is that I decided not to try to extend the cables and simply put the anode cap hole on the opposite side for both machines. This allowed me to have the neck boards oriented the way they originally were. The only slight inconvenience I found was that it was a bit harder to get the anode cap removed or accessed to discharge it. Not sure how long a bleeder resistor takes to discharge a CRT, but I definitely got some pops when I was working on the 5155. So either it doesn't have one, or it does have one but mine isn't working, or I was expecting it to work faster than it does.
Finally, there's probably a trick to it, but I struggled a fair amount trying to tighten the yoke clamp without moving the yoke and throwing it out of level. I wonder if some hot glue would have helped stabilize it until the clamp is tightened. I eventually got it to work, but it was a tad frustrating.
Thanks all! I guess now I need to learn more about the 5155 to see if I can get it working. I know there's a FloppyEmu like device, so that will be the start. Thanks all for the information!
723
It definitely is possible. See my note above about the Mac Plus CRT neck pins not working. I'd grab one from a newer SE machine to be safe. But it worked quite well.
