Hi all,
New at posting here but reading the forum has helped me resolve many issues, so hopefully someone will have an idea what could be causing this problem. I'm working on my first SE/30 repair. So far I've recapped the logic board - which restored sound, recapped the analog board - which resolved an issue where the screen would only display a single, bright vertical line, and re-soldered the analog board solder joints - which resolved a screen flickering issue. This SE/30 came with a working original Quantum 40 MB drive, and it booted to that drive just fine up until I tried to replace the ROM. At that point, booting up would get to the "Welcome to Macintosh" screen, then I would get an error that the system file had corrupted. Thinking perhaps the hard drive was on it's way out, I replaced it with a BlueSCSI that I was going to install anyway. With the BlueSCSI installed, I get the flashing "?" icon.
I took some shots of the logic board showing the SCSI controller area:
and
This would seem to be some sort of hardware issue, right? To me, the logic board and traces look like they're in good shape, so I really have no idea what's going on.
- The replacement ROM is from Garrett's Workshop - a GW4402B - GW4420B Manual.
- Taking the new ROM out and putting back in the original makes no difference, I still get the flashing "?".
- The BlueSCSI log indicates the hard drive image is being found and loaded with no errors.
- If I boot up using Floppy Emu with "Disk Utilities" loaded, I can see, access, test, update and repair the BlueSCSI, but I still get the flashing "?" when I restart.
- I tried to install System 7.5.3 onto the BlueSCSI manually from the disk images using Floppy Emu. The install completes but I still get the flashing "?" when I restart.
- I replaced the BlueSCSI with the original hard drive again and tried to initialize and clean install System 7.1, and I got the error that the system file is corrupt again.
 and
. This would seem to be some sort of hardware issue, right? To me, the logic board and traces look like they're in good shape, so I really have no idea what's going on.
