Harmful to run SE/30 temporarily without recapping?
djc6
50
12
I have an SE/30 whose logic board is in decent shape - considering its age. The Original battery was still intact (and now in the trash) so just some electrolyte corrosion.
My question, is it really harmful to run it without replacing capacitors? Capacitor C5 had come off completely.
Why would I want to run it this way? I was to do some troubleshooting to see what chip(s) are causing lack of vertical sync. So I can order the caps and other parts at the same time to save on shipping. I suspect one of the SOIC chips in the video circuitry, their legs are corroded. I wanted to run the machine long enough to probe around with my oscilloscope to hunt down the bad IC. I get a happy mac chime via the headphone jack, so the CPU is executing code and I believe this means the RAM is OK?
I am bench testing the logic board with a CayMac Vintage SE/30 Compact Analog & PSU Replacement Board and a PicoPSU. So I am not using the original power supply or analog board.
Nixontheknight
190
34
if a capacitor came off, DO NOT RUN IT, get it recapped as soon as possible
François
116
51
France
I don’t think it’s really harmful to run it, C5 is part of the audio circuitry, so you just won’t have sound. The problem is not the missing capacitor, but the leaked electrolyte from failing capacitors that is eating, and thus destroying, the circuit board. So better remove the remaining electrolytic capacitors, and thoroughly clean the board, checking for potential damage, before replacing the caps.
I think we all have run computers with failing capacitors! I sure have run my SE/30 in such a state: when the sound coming from the internal speaker is at a very low volume, even at the maximum setting, is when you know that the capacitors have failed and need to be replaced.
djc6
50
12
Thats how I felt, but I see many DO NOT RUN posts when I searched here and other forums, without reasoning why. I thought if C5 was missing the circuit is open and power is not getting to whatever would be powered. I thought the capacitors on the logic board were to smooth out voltages, and I'm not using the original power supply but instead a modern PicoPSU while bench testing.
I did this on another SE/30 and it worked out well. This is my second SE/30 restoration. I'm still looking for good ideas for cleaning up corrosion around these SOIC package chip legs in the video circuitry. One my other restoration a little vinegar worked well - kept it on the board only for five minutes or so and only in the affected areas. Any other ideas or is vinegar a safe bet?
François
116
51
France
In case you didn’t know about it already, the schematics for the SE/30 logic board have been redrawn using modern software! Get them on github. They may be useful for troubleshooting…
Reactions: croissantking
phipli
215
You shouldn't run a circuit that has leaked electrolyte on the board.
The reason is that the electrolyte allows electrolysis to happen - it strips the outer surface off pins and things corrode way faster than when a computer is just sat on a shelf. The damage tends to concentrate on the power pins, so much so that you can tell which pins are the power pins. Running a machine with no visible damage, but that the caps have leaked, then putting it back into storage for a few months gets you this :
djc6
50
12
I first blew off all the dust with an electronic duster. Then I used a spray bottle of 91% IPA and a toothbrush. On the areas with visibly corroded pins (most SOIC chips in video circuitry) I used vinegar for a few minutes and then rinsed it off with IPA. But I still feel the board could be cleaner - its hard to get in all the nooks and crannies even with a toothbrush. Any tips?
phipli
215
Not hugely helpful, but I got myself an ultrasonic for this sort of thing. Other than that the only thing you can do more is if you can find a solvent proof tray and submerge it in IPA and brush it gently with a paintbrush (make sure you have some ventilation). Make sure you let it dry before powering it on. I'm not a huge fan of scrubbing them because I worry a bristle will catch and bend or break something.
But I guess the obvious question is why not replace the capacitors? What's preventing you from fitting new ones?
djc6
50
12
I will - I explained in the first post :) I just wanted to know if it was safe to run it briefly with my oscilloscope to see whats wrong with the video circuity. I did some troubleshooting last night - appears to be a bad LS393 at UF8. So I'm going to order one of those along with the capacitors.
phipli
215
A fair. I'd forgotten you said that because I have a box full of caps and wasn't thinking.
So that is a slightly different situation, it is still... not great to run a machine without capacitors. Sometimes you get serious transients that can damage a chip, the caps soak them up. I know you mention using a modern solid state PSU, most of the time you'll be fine, and then one day you're not. Plus some of those little pico ATX things aren't as good as others (not saying yours is - just some of them seriously lie about their capacity, and some are budget items with poor quality soldering and questionable parts ratings).
If you mean running with a couple of caps missing, and that most are still there, you'll be fine.
If none were fitted and I hadn't put in an order yet, what I would have done is consider what was missing etc. I'd be happy as long as there was some capacitors on that part of the circuit, so I'd make sure I had a reasonable amount of capacitance spread around the board on the 5v, some on the 12v, -v as well. Sound... the caps on the rails I'd make sure something was there, but I would ignore the ones in series because meh - you'll just not get sound. Kind of something is better than nothing. Old macs are pretty resilient to having the "wrong" capacitance, apple just seem to have taken the attitude of making sure there is plenty enough.
Values wise, it really doesn't matter too much within an order of magnitude, not with the 47uF stuff apple put all over the board. Just tack a few through hole caps, 33uF, 47uF, 100uF, whatever, around the board.
If you're expecting to be working on more macs, I'd just order a hundred 47uF caps of your preferred type (I wouldn't use ceramic like some people do, they have a different capacitance / voltage characteristic, but regular electrolytic, tantalum and polymer would all be fine) and stick them in a drawer. Macs only tend to use a few 1uF 50v, 10uF and 100uFs other than the majority of 47uFs, other than the occasional axial... 220uF??? I forget, whatever they are on the mac II era machines. For the few oddballs I just have a box of misc SMD caps and I fish one out of that. Just remember to uprate any tantalums you use on 12v rails to 25v.
And also, never offer to recap a 7100, it will bankrupt you.
djc6
50
12
I noticed in @GutBomb's latest video, he mentions powering up an LC II after removing all surface mount electrolytic capacitors:
link should go right to that point of the video
GutBomb
7
I think the main reason people say "DO NOT RUN" to a board that needs a recap is because it's got leaked electrolyte all over the board and that stuff can eat away at stuff, but also it can be conductive and short stuff that isn't supposed to be shorted. My steps are usually to remove the caps, clean the board in an ultrasonic cleaner, then give it a good examination to see if it looks like there was any serious damage done. if I don't see anything obvious I'll power it up to see how broken it is. older 68k Macs boot up fine without caps, but I wouldn't want to use it that way long-term. that step informs me whether it's a good idea to even bother putting caps on now if the board might be a lost cause.
You're not gonna damage anything by running it without caps as a troubleshooting/testing step. The audio won't work because one of those circuits is actually dependent on the cap. Technically the audio IS working, if you hold the speaker up to your ear you'll be able to hear the audio really faintly, but it isn't amplified, as that depends on the capacitor.
Thanks for watching my video :D
jdmcs
TinkerDifferent Board DoP&G
112
76
Central Virginia
If you remove the leaking capacitors and clean the board, you're probably OK to power up the board. As others have mentioned, you won't have sound, and the system will eventually become unstable. Worst case is the board won't have enough capacitance to keep the voltage rails within tolerance and the system immediately crashes.
Or so I've been told, I'm not an EE but I know a few...
I powered up my Mac SE/30 last night with only the axial capacitors replaced to see if cleaning the board resolved the semisimac issue that it had when the seller tested it.
It did. Either that, or there was a bad SIMM in one of the banks that was preventing successful initialization, and I managed to pick the good set for testing...
And if anyone is wondering why I did it: I knew I needed to apply solder mask before recapping, to prevent shorts under caps. But I didn't want to apply solder mask before I knew that I had no trace issues, to keep from having to remove solder mask.
