68k CSEND - p2p Chat Application
Relating to a 68k application
mndeaves
6
Hi there,
Bit late with this for Marchintosh but I've started a hobby project to build a p2p chat app in C that runs on modern OS's and Classic Mac System 7 with MacTCP. The POSIX version is more advanced in terms of features but I have managed to get the classic Mac version to do UDP broadcasts so that it is registered by the POSIX version.
The code is on GitHub and I'm documenting it as I go, especially with tags when I reach a particular milestone I'm proud of. I'm not a C guru, I studied it at university a couple of decades ago and am doing this for fun. I've a Performa 6200 and a Mac SE, so far I'm testing the classic build on System 7.5.3 on the Performa.
I did a video demo of where I am up to on YouTube
I'm using retro68 (which is amazing) to write and compile C code with VSCode on Ubuntu. The idea is that I try to share as much plain vanilla C code as possible between the POSIX and Classic Mac version, which so far is going well.
Just seeing what sort of interest there is out there for feedback from proper C developers or those just following along for the love of old Macs really.
Cheers!
mndeaves
6
I continued to work on building out the MacTCP/System 7 build of the application. It has taken me a while even with the help of AI to trawl through the MacTCP documentation but I've finally got UDP and TCP two-way communication working between my Mac (System 7.5.3) and Ubuntu machines!!!! I'll do a video of the Mac and Ubuntu builds talking to each other this weekend.
I think with a bit more work I could package up the UDP and TCP code as a library that I could use in other applications. My plan is to implement the text box and sending of broadcast/single peer messages in the Mac build in the next week or so and then take more time to refactor the code before making a version that works with OpenTransport.
I will look at that GUSI library, I'm just kind of hooked at the moment on getting it to work with MacTCP.....
mndeaves
6
Some screenshots might be nice.
I spent some time tonight tidying up the classic mac build and getting it to pretty much feature parity with the POSIX build... they can now discover each other over the network via UDP and send messages to each other over TCP (direct by choosing a peer or as a broadcast to all discovered peers).
The screenshots here are a bit rough but show the communication working! I had to export a PICT via photoshop 3 on the mac to then open in GIMP on ubuntu but it didnt seem to read it quite right! On the ubuntu side the top half of the picture is a previous run of the app and then the bottom half is me firing it up again (testing the discovery side of things)
Next steps:
  1. Refactor/refine the whole code base some more, especially the networking UDP/TCP code for MacTCP so that
    1. I can use it in other projects (I want to make a networked game where players instantly join if on same network)
    2. i can look into possibility of sending files between peers
    3. I can start on an OpenTransport build
  2. Implement the ability to set the username for the mac version - preference file maybe or just a text box (at the moment it is hard coded to 'mac')
  3. Implement a menu system with at least Quit option (so you don't have to use the close window button as only way to quit)
I know enough C to be dangerous. The Mac C programming has been only possible this quick for me with the use of AI for the books and generating code as I go... and a lot of getting it to comment code and then I sit and read it/tweak it...
Can't believe it works! I'll do a much better video of it all together this weekend... if you toggle debug mode on either end you can see the UDP chatter going on etc....
Reactions: djc6
mndeaves
6
Work continues.. still haven't made a video but I have pushed the code base towards being able to support OpenTransport as well as MacTCP with the addition of a network abstraction layer. Was tinkering around with Claude 4 to help me out and it's very impressive. The new layer essentially pushes all the MacTCP (or any other TCP/IP implementation) down from the network, discovery and messaging logic and into a set of implementation files that handle how to manage the state of the network driver.
So for now I only have MacTCP still, but the structure is there to start adding OpenTransport without having to modify loads of code all over the place, we create an OT implementation compliant with the abstraction layer..... hopefully.
You can see what I mean here in the MacTCP implementation file....and the network_abstraction
mndeaves
6
and here is a video of it in action.... I added 'machine mode' to the POSIX version which allows it to be programmatically controlled... so I demonstrate using it to chat to Claude from System 7
mndeaves
6
I've got working MacTCP and OpenTransport builds now... I tried for ages with Claude to refactor the code into one with support for both networking stacks, but they work in completely different ways. So, I've duplicated some code and shared the rest between the two, and use build files to compile separate MacTCP, OpenTransport and POSIX binaries. Working through further refactoring now to tighten up the classic mac builds. All three types of peer can communicate really well over TCP and UDP now with direct messages to one another or broadcast messages to each of their peers.
Started a build to run on System 6.0.8 with my Mac SE but the 4MB ram constraint there is a problem... plan is to further refine the mactcp and OT builds to minimise as much code as possible and then look at a System 6.x build with MacTCP on a machine with more than 4MB as a start...
If anyone would like to try them here are links to the .bin files (use binUnpk to uncompress)
OpenTransport Build (tested on a Performa 6400 System 7.6.1 with OpenTransport 1.1.1)
MacTCP Build (tested on a Performa 6200 System 7.5.3 with MacTCP 2.1)
Both have a Perform Test option in the file menu which kind of works but also needs improving... the idea is I use that and the extensive logging to help improve performance etc...
