Important question, Can I use a single pump if one LCS pump is broken!!!!!
Cyclone740
120
Now I have a really insane question, if I do the plumbing right, could I run my system using only one pump?
Yes one of the pumps just up and died on my after the PCB released the magic smoke and burnt itself (see pictures). Now I think that I have found a replacement PCB, but I would like some help identifying if it will work and also if anyone might have some spare units or something like that, or even a place I can get the parts cheap(ish, basically not $70 to $400).
In the mean time I got to thinking and believe that I have mapped out a loop that could feed both loops from one pump, now I know that there might need to be some wiring modifications done, but I was just wanting to know if I would be able to pull this off and have it run just fine, or if it would burn the motor out? Also would adding a resistor to the wires to bring the voltage down to 10v - 11v be OK too?
Cyclone740
120
OK!!! Update this is my plan for a single pump dual loop. Please excuse how crude it is, I am needing to get proper tubing (and maybe fittings and joints and maybe even pipe), but I want to know if this would work at all. So I will just do a quick test to see if it can pump water through it.
Please if anyone knows if this will work please let me know ASAP.
Cyclone740
120
I did find some other threads in google of other people using alternate pumps (other part numbers), but I have not seen anyone convert a dual pump to single pump. In theory it should work as long as the pump can keep going. @HrutkayMods has several G5 videos on Youtube about converting LCS to air cooled as well.
What pumps can I use? Is it able to be any type of pc pump? Also where would I get the air cooled heatsinks?
Cyclone740
120
Also it was kinda working bleeding the system is a nightmare. And I also found out that the pmv PCBs die because of a particular component.
I will look into the pump options.
560
There is a ton of stuff out there...
http://tenfourfox.blogspot.com/2021/07/and-now-for-something-completely.html
https://forums.macrumors.com/threads/comprehensive-guide-to-servicing-g5-quad-lcs.2455017/
https://68kmla.org/bb/index.php?threads/quad-g5-lcs-overhaul-pump-replacement-pwm-dependant.39750/
https://inverary.net/LCS/Power Mac G5 Quad LCS Restoration, A-Z Guide, v1.0.pdf
Air cooled conversion would likely require salvage from another air cooled G5, or parts units off your favorite reseller site.
Cyclone740
120
Thank you so much for this information, I am sorry for asking this information of you when I should be able to find it myself, the problem is that I find it very difficult to sift through information effectively without going down like 5 different rabbit holes.
Also if you don't mind me asking, do you know if the replacement PCBs from DIYINHK with the PWM will work as drop in replacements for the old ones? And if not is there a write up or a guide showing or explaining how to make it work with the G5 PWM? Like is it just a matter of swapping a chip from the old board onto the new one? Or what do I do?
309
123
I don't know anything about that. The PCBs from DIYINHK are not mentioned in the air cooling links I posted.
They are mentioned here:
Past summer project - G5 Quad LCS rebuild
LCS Issues Late 2005 Quad
