Hello Tinker Different! I finally got my very own compact mac, a dream of mine. It works very well now after a recap, both logic and analog board.
The CRT image has a slight dip at the top and middle, almost like Mr. Macintosh here is scowling at me (this also warps straight lines down towards the center in the image). Another, the left and right top corners appear to flick towards the center (vertically speaking) of the screen. The side and bottom of the edges are both completely sharp and normal.
Any ideas? Could it be an incorrect capacitor or as simple as a tweak to the CRT controls?
Many thanks!
UPDATE 1:
As per _nec6678's suggestion, I fiddled with the adjustments on the analog board itself. No changes to image in regards to the dip nor twitching image. I have yet to re-position the yolk assembly itself.
UPDATE 2: All Good.
Based on what I learned here, I managed to successfully adjust the screen geometry. While not perfect, I no longer have a scowly mac, or one with cocked eyebrows. Thank you!
Many thanks!
UPDATE 1:
UPDATE 2: All Good.
