PowerMac 7100 and Linux
145
47
I searched my Copland disk image for occurrences of a snippet from the nvramrc and found 7 occurrences.
I mounted the disk image and searched only the HFS partition which also has 7 occurrences which means all occurrences are in the HFS partition.
I take the offsets and divide them by 512 to get block numbers, then use fsck_hfs to get inode numbers.
I mount the disk in Leopard which supports HFS so that I can convert inode numbers to file paths.
Leopard doesn't have the -B option for fsck_hfs.
# Note grep -b doesn't work well in earlier macOS versions - it gets offset of line instead of occurrences in the line.
grep -a -b -o 'boot-device 2dup drop " /AAPL,ROM" comp if try then' Copland.dmg | perl -pe 's/:.*//'
hdiutil attach -nomount Copland.dmg
grep -a -b -o 'boot-device 2dup drop " /AAPL,ROM" comp if try then' /dev/disk15s9 | perl -pe "s/:.*//" > /tmp/offsets.txt
perl -ne '
    printf("%d ", ($_ / 512));
' /tmp/offsets.txt > /tmp/blocks.txt
fsck_hfs -B /tmp/blocks.txt /dev/disk15s9
# Mount the disk in a version of macOS that supports HFS, such as Leopard
# because FuseHFS does not use HFS inode numbers
diskutil mount disk15s9
GetFileInfo="GetFileInfo"
command -v GetFileInfo > /dev/null 2>&1 || {
    GetFileInfo="/Developer/Tools/GetFileInfo"
# Use this to get the volume id of the Copland partition:
stat /Volumes/Copland
# Use this to get the path for a file with volume id/inode number:
"$GetFileInfo" -P "/.vol/234881036/721"
# If it doesn't work then use find:
find /Volumes/Copland -inum 721
# Or use ls:
ls -liR /Volumes/Copland
All the important occurrences seem to be in Mac OS Loader. Here's a list of interesting resources in that file:
'opfw' (0).                         \ DBOF xcoff for NuBus Macs
'ofpt' (1, "OFPatches").            \ patches for OF not DBOF?
'ofpt' (2, "CONTROL Driver").       \ control
'ofpt' (3, "Platinum Driver").      \ platinum
'ofpt' (4, "Name Registry NVRAM").  \ OF code to load nvram properties into OF?
'ofpt' (128, "auto-boot?").         \ auto-boot? default value?
'ofpt' (129, "use-nvramrc?").       \ use-nvramrc? default value?
'ofpt' (130, "boot-command").       \ boot-command default value for OF?
'ofpt' (131, "load-base").          \ load-base default value?
'ofpt' (4177, "nvramrc").           \ nvramrc for OF not DBOF?
'ofpt' (-15, "nvramrc").            \ nvramrc for DBOF
'ofpt' (-14, "boot-command").       \ boot-command default value for DBOF?
'boot' (1).                         \ default boot block
'nkld' (128).                       \ new kernel loader?
'2ldr' (1, "SecondaryLoader").      \ secondary loader
'nvrm' (0).                         \ DBOF nvram source (modified by above overrides?)
I guess you'll want to look at 'ofpt' (131) and 'nvrm' (0).
load-base and real-base are at a specific offsets in the nvrm.
speakers
144
96
San Jose, CA
peak-weber.net
Thanks for this effort. It does seem to show that the Loader constructs nvram in memory from using a number of its resources.
This is consistent with what I see in ResEdit for the Loader:
This is taken from the install kit. I can edit 'auto-boot?' to false, re-install and have it take effect. However, changes to 'load-base' have no effect and 'real-base' is absent.
Looking at the Copland Installer, I see the resource 'nvd$':
This appears to be a dictionary of OFW variables. Perhaps it's their offsets into the in-memory nvram???
The 'nvrm' resource is 8k of mostly zeroes but with a small chunk containing the values of 'boot-command', 'input-device', 'output-device', 'diag-device' and 'boot-device'. Although after installation it also includes a string starting '" kbd" find-device'.
Note that on my real 7100, I can (using the original subject of this thread) boot Debian to poke in the Copland volume. The tools may be more reliable than Leopard's.
145
47
Appears to be C strings followed by variable type and bit number or offset (01=boolean, with bit number, 02=number with offset to value, 03=string with offset to string)
So `real-base` is at offset 0x10 in the nvrm resource. It seems to have a value of FFFFFFFF = -1 in the Mac OS Loader resource fork.
You can look at the DingusPPC source code to see the format of the Old World NVRAM variables.
I think New World NVRAM variables use strings for the number types. Look at the DingusPPC source code to be sure.
The string starting with '" kbd" find-device' is for the nvramrc string variable.
speakers
144
96
San Jose, CA
peak-weber.net
I've now confirmed that the nvrm resource of Mac OS Loader can be edited to change the initial value of 'real-base' and 'load-base' variables etc. And it is indeed necessary to update the checksum word (16-bit word offset 2) of the resource.
I use DeRez on OSX to decompile the resource fork of Mac OS Loader to produce a text description file of the nvrm resource. This file can be updated with modified values and a python script used to update the checksum. I could't convince Rez to reconstitute the binary, so I use ResEdit to edit word changes into the active MAc OS Loader image in Mac OS Folder.
However, the Copland DBOF seems intolerant to changes to real-base: only -1 or 0x400000 appear viable :(
And I still can't find a load-base setting to avoid claim failure when loading client code (ofwboot in particulat). I'd like to get a memory map of allocated spaces managed by OFW so I could resolve this.
145
47
You have the Open Firmware code (assembly and Forth) from my dump. You can look at the code to see what's happening. I don't know when real-base and load-base are setup/used - is it before Open Firmware has started (in System 7), or in the Open Firmware init code (Part1.txt) or in Open Firmware (Part2.of)?
The available property in /memory (memory ihandle in /chosen) shows physical RAM addresses that are available.
The available property in the cpu node (mmu ihandle in /chosen) shows virtual addresses that are available.
The translations property in the cpu node has a list of current translations.
The lists of ranges are kept in queues (mem-avail and vert-avail). Here's some code I created for later Open Firmware versions that can dump them.
: dump-vt { ; q entry }
    cr
    translations dup -> q
    >q.next@ -> entry
    begin
        entry q <>
    while
        entry >vt.virt @ ."  virt:" 8 u.r
        entry >vt.size @ ."  size:" 8 u.r
        entry >vt.phys @ ."  phys:" 8 u.r
        entry >vt.mode @ ."  mode:" 8 u.r
        cr
        entry >q.next@ -> entry
    repeat
: dump-avail ( q -- ) { q ; entry }
    cr
    q >q.next@ -> entry
    begin
        entry q <>
    while
        entry >fa.addr @ ."  addr:" 8 u.r
        entry >fa.size @ ."  size:" 8 u.r
        cr
    repeat
\ available physical address for RAM \ ra-prop|mem-avail|claim-mem|release-mem
\ words: claim-mem release-mem
\ device: memory ; words: claim = claim-mem, release = release-mem ; properties: available
\ - on initialization, the amount of RAM detected at startup is released.
\ - claims first 16K of RAM for interrupt vectors
\ - used during probing of PCI (with mapping)
mem-avail dump-avail
\ available physical addresses for I/O \ real-avail|claim-real|release-real
\ words: claim-real (for claiming physical addresses for I/O and PCI devices) release-real
\ - on initialization, releases the range 0x80000000..0xFFFFFFFF.
real-avail dump-avail
\ available virtual addresses \ va-prop|virt-avail|claim-virt|release-virt
\ words: claim-virt release-virt
\ device: cpus ; words: claim release ; properties: available
\ device: macparts ; words: map-space (claims mem and virt and maps them)
\ - on initialization, releases ranges 0x0000000..virt_base-1 and virt_base+1MiB..rombase=0ffc00000-1
virt-avail dump-avail
\ translations
\ device: cpu ; properties: translations
dump-vt
dump-vt
@startvec contains a list of fields. Many of them point to structures in memory. The following code lists the fields of @startvec and the values for each field:
\ For Open Firmware 2.4 and earlier, >h.count needs to be changed to 4+ because xt>hdr points to >h.flags instead of >h.link
: dump-fields { addr fcodestart fcodeend ; token ptr }
    cr
    fcodeend 1+ fcodestart do
        i ." 0x" 4 u.r space
        i get-token drop -> token
        0 token execute 4 u.r space
        addr token execute dup 8 u.r space
        token name.
        #out @ d# 42 < if d# 42 #out @ - spaces then
        @ -> ptr
        ptr 8 u.r space
        \ check if the field might point to a xt token and if so, output its name
        ptr @startvec u> ptr 7 and 0= and if
            ptr xt>hdr 4+ ( >h.count ) dup c@ + 8 + -8 and ptr = if ptr name. then
        then
        cr
    loop
: dump-startvec
    \ Dump all fields of @startvec
    @startvec 48a 4d1 dump-fields ;
dump-startvec
I believe copland @startvec fields have fcode numbers 48a ... 4d1. This will be different in different versions of Open Firmware.
Once you dump the fields and their values, you can sort by values to get a memory map (but some fields are not pointers so you should remove those from the memory map).
Here's an example from a Beige G3 with OF 2.4:
\ Open Firmware memory map for OF 2.4
\ fields marked "\ real" store a real address (change FF8 to 004)
FF800000  >real_base     \ real
FF800000  >virt_base
FF800400  >dp
FF800800  >rp
FF800C00  >lp
FF801000  >fp
FF801800  >ep
FF801C00  >tib
FF802000  >noname
FF804000  >ttp
FF808000  >regsvalid?
FF808940  >endiango
FF809D10  >'<sc-int>     \ real
FF809E18  >'cientry      cientry
FF80A350  >'(poplocals)  (poplocals)
FF80D0B0  >'ferror       ferror
FF80D8D0  >'my-self
FF80F738  >'cold-load    cold-load
FF811FA0  >'abort        abort
FF8179A8  >'quit         quit
FF818350  >'cold-init    _cold-init
FF819338  >'excp         _exception
FF819638  >'syscatch     _syscatch
FF829498  >'cicall       cicall
FF82A3D0  >ciwords
FF85D4E8  >word-list
FF85D524  >here
FF8D0000  >free-bot
FF8D6000  >ttp800
FF8DF600  >intvectv
FF8DF600  >intvectr      \ real
FF8DF800  >ciregsv
FF8DF800  >ciregsr       \ real
FF8DFA00  >ofregsv       ^-720600
FF8DFA00  >ofregsr       \ real
FF8DFC00  >real-vt-hd    \ real
FF8E0000  >free-top
FF8E0000  >htab          \ real
FF8F0800  >dl-buf
All of these are in the Open Firmware range (1MB virtual address range FF800000 .. FF8FFFFF). Later versions of Open Firmware have larger ranges (up to 3 MB in the latest).
You can convert physical addresses to/from virtual addresses using virt->real[icode] and [icode]real->virt but only for addresses related to virt_base and real_base? Otherwise, you can use the translate method of the mmu ihandle (or use do-translate anywhere) to convert a virtual address to a physical address which will use the translations list.
Since we can dump most of the Open Firmware DBOF, we can also modify it using a reverse process (may need to update some fields in @startvec which has default values in the beginning of DBOF). The Forth fcode tokenizer needs to be updated to handle some Apple Open Firmware features.
speakers
144
96
San Jose, CA
peak-weber.net
Thanks greatly for these code snippets which (except for dump-vt) work well on my 7100 and Beige G3.
The main issue with the 7100 appears to be its discontiguous RAM. Banks are separated by awkward holes that results in OFW claim failures loading the BSD Booter, ofwboot.xcf. There's also reserved chunks of low memory used by the keyboard and framebuffer requiring special handling.
I've built a modified BSD booter that works around the memory discontinuity and this now boots. So .. some progress!
145
47
You should be able to correct dump-vt for the versions of OF that it doesn't work on.
It works for me with DingusPPC pm6100 with Copland DBOF. What error are you seeing?
 virt:00000000 size:00040000 phys:00000000 mode:00000000
 virt:00040000 size:00040000 phys:00040000 mode:00000028
 virt:F8000000 size:00001000 phys:F8000000 mode:00000028
 virt:FF800000 size:00100000 phys:00400000 mode:00000010
 virt:FFC00000 size:00400000 phys:FFC00000 mode:00000000
The translations queue is hidden (words are headerless) in OF 1.0.5 and on Beige G3 with OF 2.0f1. Is that the ROM you have?
later Beige G3's have OF 2.4 which does not use headerless.
The following code in nvramrc will add the hidden words:
h# fb2 get-token drop execute \ (install-console)
." hello" cr
defer translations
h# 80d get-token drop to translations
struct
/n field >q.next
/n field >q.back
constant /q
struct
/q field >vt.queue
/n field >vt.virt
/n field >vt.size
/n field >vt.phys
/n field >vt.mode
constant /vt-list-size
: >q.next@ dup >q.next @ + ;
." [ probe-all" cr
probe-all
." ] probe-all" cr
banner
It calls (install-console) so that it can output text to serial port before PCI slots are probed (useful for debugging). You can remove that code if you're using the screen and keyboard for I/O.
The memory holes should be described by missing ranges in the memory available list. I think an Open Firmware boot loader should honour the info in that list.
Are the chunks of low memory not described by holes in the available lists or by translations?
Here's code to test all pages in the 4 GB memory range to see what virtual addresses are mapped. The errors are PPC exception vector addresses (200 for machine check, 300 for DSI, 900 for decrementer exception).
: test-ranges ( max min -- )
    { _max _min ; _rerr _err }
    cr
    -1 -> _rerr
    _max _min do
        ( ) i ['] l@ catch ?dup if -> _err drop else 0 -> _err drop then
        _err h# fffff and 900 = if
        then
        _err _rerr <> if
            i 8 u.r ." : "
            _err if ." error " _err 8 u.r then
            cr
            _err -> _rerr
        then
    1000 +loop
-1 0 test-ranges
The ranges should align with those in translations
speakers
144
96
San Jose, CA
peak-weber.net
It does work for OF 2.4 on my G3 (I mispoke) but on DBOF 2.0, I get translatiions, no word as you surmise.
." hello" cr
defer translations
struct
/n field >q.next
/n field >q.back
constant /q
struct
/q field >vt.queue
/n field >vt.virt
/n field >vt.size
/n field >vt.phys
/n field >vt.mode
." [ probe-all" cr
probe-all
." ] probe-all" cr
banner
Using the above, I get this error when running dump-vt:
0 > dump-vt
DEFAULT CATCH!, code=FFFFFFF3 at   %SRR0: FF80BC14   %SRR1: 00000030
 ok
On-board 8MB RAM is 0x0-0x800000 with additional 8MB SiMMS at 0x1000000 (bank1) and 0x5000000 (bank2):
0 > mem-avail dump-avail
addr:00080000 size:00080000
addr:00200000 size:00200000
addr:00500000 size:00300000
addr:01000000 size:00800000
addr:05000000 size:00800000
 ok
The booter ofwboot.xcf is built to load/run at 0xe00000 which can't be honored.
Your test-ranges snippet fails for me as follows:
0 > -1 0 test-ranges
00000000:
00080000: error FFF00300
DEFAULT CATCH!, code=FFF00200 at   %SRR0: FF8096B4   %SRR1: 00000030
 ok
145
47
But translations should exist as a word in Copland DBOF 2.0:
0 > see translations
buffer: translations  ok
Are you using Copland D11E4 or an earlier version? I haven't looked at earlier versions.
0 > dump-vt
 ok
80d get-token drop is only going to work inside the nvramrc before probe-all
At the OF prompt, 80d get-token drop will return the execution token of ferror which contains -D throw which is the code -D=FFFFFFF3 that you see in the error message. Basically, the error passed to throw is how you find where the error came from.
0 > h# 80d get-token drop (see)
: ferror
  -D throw ; ok
Since translations is not a word in the Open Firmware IEEE-1275 spec, it's fcode number 0x80d is a user defined number (≥0x800) and it could be different in other versions of Open Firmware if any words were added or removed between versions before translations is defined. DBOF of Copland D11E4 and OF 2.0f1 both happen to use 0x80d for the translations word. Here is the fcode number used in some other versions of Open Firmware:
1.1.22       80d
2.0 Copland  80d
2.0a9        80d
2.3          80d
2.4          80d
3.1.0f1      810
3.1.3f2      810
3.1.3f3      810
3.2.4f1      810
3.3.2f1      810
4.1.0f1      810
4.1.7f4      810
4.1.8f5      810
4.1.9f1      810
4.2.5f1      158d
4.2.7f1      158d
4.2.8f1      810
4.3.2f1      158d
4.4.0f1      1590
4.4.1f1      1590
4.4.5f3      1646
4.4.8f2      1647
4.5.4f1      1693
4.5.7f1      1717
4.5.8f1      1718
4.6.0f1      1717
4.6.2f1      171a
4.6.4f1      1734
4.7.1f1      17c4
4.8.5f0      1860
4.8.7f1      1949
4.8.9f4      198f
4.9.3f0      1a5b
4.9.4f1      1a5b
4.9.5f3      1a6e
4.9.6f0      1a6e
5.1.5f2      1816
5.2.7f1      1ab8
Any version not listed is one I don't have or where translations is defined as a headerless word (where the name is not included in the fcode).
Note how versions of OF after 4.2.5f1 have 16-bit fcode numbers (against the IEEE-1275 spec of 12-bit fcode numbers). Apple decided they needed more fcode numbers.
Your available ranges overlap 100% with the RAM ranges that you listed as expected.
The RAM layout is described by the reg property of memory
For my pm6100 in DingusPPC, I see the RAM DIMMs have consecutive ranges when using 8+8+8 MB:
0 > dev /memory  ok
0 > .properties
name                    memory
device_type             memory
reg                     00000000  00800000
                        00800000  00800000
                        01000000  00800000
available               00080000 00080000
                        00200000 00200000
                        00500000 01300000
All the ranges in the available list overlap 100% with ranges in the reg list as expected.
Using 8 (onboard)+64+64 MB DIMMS results in discontiguous memory ranges:
0 > dev /memory  ok
0 > .properties
name                    memory
device_type             memory
                        10000000  04000000
                        08000000  04000000
                        00200000 00200000
                        00500000 00300000
                        08000000 04000000
                        10000000 04000000
All the ranges in the available list still overlap 100% with ranges in the reg list as expected.
It's easier to see if you convert the start length pairs to start stop ranges:
reg: [00000000, 00800000)  available: [00080000, 00100000), [00200000, 00400000), [00500000, 00800000)
reg: [08000000, 0C000000)  available: [08000000, 0C000000)
reg: [10000000, 14000000)  available: [10000000, 14000000)
Hence the need for you to create your modified BSD booter.
00000000:
 ok
Strange that it couldn't catch that machine check exception. I have catch in all the places that it is needed. I wonder if a double catch would work? You could try changing both occurrences of l@ to c@
145
47
Here's an implementation with a second level of catch:
0 value _rerr
0 value _page
0 value _err
    do
    	i to _page
        ( ) i ['] l@ catch ?dup if to _err drop else 0 to _err drop then
        then
		_err _rerr <> if
            i 8 u.r ." : "
            cr
            _err to _rerr
        then
    1000 +loop
: test-all
    cr
	0 to _page
    -1 to _rerr
    -1 0 test-ranges
	begin
		( ) -1 _page ['] test-ranges catch ?dup if to _err else 0 to _err then
		_err if
	        _err if _page 8 u.r ." = error " _err 8 u.r then
            _err to _rerr
            _page h# fffff000 < if
	            _page h# 1000 + to _page
	            false
	        else
	        	true
	        then
		else
			_page h# fffff000 =
		then
	until
test-all
speakers
144
96
San Jose, CA
peak-weber.net
Yep, D11E4.
And I do see translations. And dump-vt is now working for me!
I've mucked further with the memory config which may be the issue (again). DBOF didn't boot when I had 8+32+32+32+32; it booted with 8+0+0+8+8 but dump-vt failed; now with 8+8+8+0+0 dump-vt is good.
145
47
Neither changing l@ to c@ nor using the new method makes a difference. Same error exactly. :(
An external variable _page is used to keep track of where it stopped. What's the value? Can you read from the address manually?
cr _page 8 u.r cr
cr _page c@ . cr
cr _page ['] c@ catch if ." error: " 8 u.r cr else . then
If you give an example of a bad address, then I can make DingusPPC do the same exception to see if test-all has the same behavior in DingusPPC.
I don't think you need to get further into this problem for your boot loader. If one wanted to get to the bottom of this problem, then one might do the following :
Check the exception table code to see what's happening. Is the exception handler for 200 (machine check) different than 300 (DSI)?
Use the python tbxi dump command to dump the pm7100 rom.
https://github.com/elliotnunn/tbxi
There's an ExceptionTable file created in the dump. Compare that with what Open Firmware has (FFF00000, FFF0C000]
FFF00000 C000 dump
I guess they would be different since OF has different requirements than whatever the ROM needs to do for normal boot?
Compare the 256 bytes of FFF00200 and FFF00300.
I guess they would be similar in normal OF but maybe different in DBOF?
Since DBOF is the only version of Apple Open Firmware with a disassembler, try this:
FFF00000 dis
dis may encounter an exception when disassembling some instructions (I'm not sure why - I think it might try to read from the effective address of some branches?). badaddress l@ . those addresses, then continue dis at the badaddress + 4.
My DumpMacRom.sh script can also disassemble PPC instructions.
https://github.com/joevt/OpenBIOSStuff
Use it like this:
OpenBIOSStuff="/Volumes/Updates/Docs/Open_Firmware_and_Forth/OpenBIOS/joevt-OpenBIOSStuff"
PATH="$OpenBIOSStuff"/detok/obj-amd64:"$OpenBIOSStuff"/toke/obj-amd64:"$OpenBIOSStuff"/macOS:/Volumes/Work/Programming/lzss/joevt-lzss:/usr/local/sbin:/usr/local/bin:/usr/bin:/bin:/usr/sbin:/sbin:/Users/joevt/Library/Python/2.7/bin:/opt/X11/bin:/Library/Apple/usr/bin
thefile="path to ExceptionTable"
DumpStartDir="$(dirname "${thefile}")/DumpStart"
fullpath="$(realpath "${thefile}")"
mkdir -p "$DumpStartDir"
pushd "$DumpStartDir"
	DumpMacRom.sh -d "${fullpath}" > /dev/null
popd
The relevant file that is created in this case is All.txt.
The Open Firmware part of a ROM is saved by tbxi in a file called OpenFW
My DumpMacRom.sh script was meant for that part of a ROM. It dumps the PPC assembly into Part1.txt and fcode (converted to Forth) into Part2.of
The tbxi dump may include a DeclData file. My SlotsParse command can parse the contents. It contains SlotManager data for the Mac. PCI Macs have a minimal DeclData. New World Macs have none.
https://github.com/joevt/SlotsDump
Use it like this:
./SlotsParse "DeclData" > "DeclData.parsed.txt"
Some files produced by tbxi may be PEF or XCOFF.
Use the file -b command to detect the type of the file.
MPW has commands DumpPEF and DumpXCOFF that can disassemble those file types. You can use MPW commands in modern macOS:
https://github.com/ksherlock/mpw
145
47
didn't boot - are you talking about booting Copland or getting into DBOF? Are you saying you can't get into DBOF with 8+32+32+32+32?
Not sure how dump-vt could fail. word not found? Not sure how words can disappear depending on RAM layout unless something got corrupted?
Output from dev / ls unselect-dev " devalias" evaluate " printenv" evaluate dump-device-tree words in each case might be interesting.
You'll probably want your BSD boot loader to work with any possible memory config?
speakers
144
96
San Jose, CA
peak-weber.net
It failed to launch Copland with 136MB. I don't know if it got into DBOF because that was before I discovered how to override auto-boot?
I'll need to re-install the larger SIMMs and that's awkward on the PM7100 since memory is under the drive chassis which requires the machine to be dismantled. Later form-factors like the G3 were much more serviceable in this respect.
speakers
144
96
San Jose, CA
peak-weber.net
I'm blocked in my attempts to get DBOF to boot a BSD kernel, so I back-tracked to answer the 136MB booting question: DBOF does boot and reach the CLI with 'auto-boot?' flals. Copland proceeds to the "Microkernel initialization starting..." message but gets no further. I can connect the remote debugger at this point and I see a message about no kernel stack which suggests memory issues.
The problem with DBOF loading a BSD kernel comes down to the inability to override the 'real-base' config variable. DBOF oninsists loading at 0x400000 (4Meg) and that doesn't leave enough space to load a kernel that's based at 0x100000 (1Meg). The code to load DBOF lives in the Mac OS Loader image which the ROM loads at boot (in place of the standard System image). But I've not been able to reverse-engineer the Loader to discover where the load address is set and why it's glued to 0x400000 on my PM7100. I can't persuade MPW or Ghidra to produce anything useful from the Loader binary.
145
47
The resource nkld_128 of Mac OS Loader seems to be 68K code that loads opfw from Mac OS Loader.
Mac OS Loader has a data fork that contains a PEF (search for Joy!peff) at an offset that is not zero. You can extract the PEF and disassemble that. I don't know what the data before the PEF is for.
I used Jasik's Mac Nosy II to disassemble both of those. It doesn't want to disassemble PPC resources that are not PEF.
With my fork of DingusPPC, you could enable instruction recording, then dump the instruction log when it reaches Open Firmware to see the instructions that happened before Open Firmware. It might be more informative to use the step 1000000 command which outputs a million instructions at a time or use the step until command (when you know the address for Open Firmware). The output in these modes will include Open Firmware names when it reaches Open Firmware code. Of course there are some big loops that you'll need to step through such as moving memory etc so it may take a while.
Did you check my dump of the DBOF Open Firmware code to see if real-base can be modified? Probably the modification needs to be made before Open Firmware starts.
https://www.dropbox.com/scl/fi/33je...ey=s6objqfrdrv0zh9l0gvn8dhid&st=k0jvlnmn&dl=0
@startvec has initial values defined in Part1.txt at offset 0x3c (after the XCOFF header). Part1.txt has zeros for some fields in @startvec. I guess these fields may be modified after opfw is loaded.
real_base is in @startvec at offset 0x2c (0x68 in Part1.txt).
I should change the offsets listed in Part1.txt so that it starts at -0x3c to match the addresses in RAM.
  • MacOSLoaderNosy.zip
speakers
144
96
San Jose, CA
peak-weber.net
I also chopped off the preamble and fed the PEF fto Ghidra.
Your Mac Nosy listing is much more useful than Ghidra's! But it appears that this entire PEF is the Tertiary Loader responsible for loading Copland. This loader runs as an OFW client after DBOF has been loaded. The 'nkld' resource certainly loads DBOF and nvram but it's still not clear to me what code sets up the memory environment prior to this.
I've made every effort to avoid runnning DingusPPCC but I've failed! I now have your fork running on my M4 MBA. It's using the pm6100 ROM and boots the same MacOS/Copland disk image I run on my pm7100. I find I need to have a CD image configured also .. otherwise I get a fatal SIGSEGV. With --debugger set I can release the emulation with the CapsLock down plus auto-boot?=false, and I see the emulation pause at the OFW CLI. But I haven't worked out how to see and interact with the CLI. Neither --serial_backend=studio nor- -serial_backend=socket works .. I suspect input/output=ttyb conflicts here.
I've tried instruction stepping but I see a failure after a few tens of millions of instructions:
40310040: 7C0F01A4 mtsr 15, r0 ; in{ r0:0 } out{ sr15:0 } libc++abi: terminating due to uncaught exception of type std::invalid_argument: Unknown register 40310044: 7C1503A6 mt r0 ; in{ r0:0 } out{ :( 624.273s) main.cpp:60 INFO| Shutting down...
Some sort of timing issue may exist.
It can be modifed but only -1 and 0x40000 work!
145
47
Since input and output default to serial port B (printer port), you should set serial port B to socket. Easiest way to do that is set both ports to socket like this:
--serial_backend=socket --serial_backend=socket
The first occurrence corresponds to port A (modem port) because that is first in the device tree.
The second occurrence corresponds to port B (printer port) because that is the next serial port in the device tree that has not had it's property overridden by the command line yet.
In Terminal.app, in a new window, you can open the serial port B socket when DingusPPC has started with this:
socat UNIX-CLIENT:dingussocketb -,cs8,parenb=0,echo=0,icanon=0,isig=0,icrnl=0
You don't need to open serial port A. But if you want to, then open another window and use this:
socat UNIX-CLIENT:dingussocket -,cs8,parenb=0,echo=0,icanon=0,isig=0,icrnl=0
For an empty CD-ROM drive, it's probably best to not include the CD-ROM drive at all until SCSI CD-ROM emulation in DingusPPC is fixed to support empty CD-ROM drives. Use this:
--cdr_config=
The following makes DingusPPC stop at the DingusPPC debugger just before starting the CPU (at instruction address 0xFFF00100):
--debugger
Type help for a list of instructions.
Type go to continue normal execution.
si 1000000 to step a million instructions.
until 0x######## to execute until a certain instruction address.
The following allows you to get into the DingusPPC debugger when DBOF has loaded (press CapsLock when the gray screen appears when booting the Copland HD to get DBOF loaded).
--debug_copland=1
Then you can use the DingusPPC setenv command to change nvram variables (without being at the Open Firmware prompt in the socket window yet). This means you change auto-boot? from true to false here and it will get you into Open Firmware. DingusPPC will save the Copland nvram and use it to override the nvram for next boot. nvram gets saved only if you exit DingusPPC normally such as with a quit command from the DingusPPC debugger prompt.
Here's some other options I use:
--workingdir "/Users/joevt/dingusppc/6100" --bootrom "pdm.rom" --machine pm6100
It is useful to have a separate --workingdir for each machine so that each machine can have its own nvram and pram. The working directory can contain any ROM files you need (pdm.rom is the 6100 rom, but you can have ROMs for NuBus and PCI cards as well).
You could try --machine pm7100 but we haven't worked on other PDM machines that much (for RAM allocation, 8100 is missing the second SCSI bus, etc.)
The following gives maximum RAM for a 6100 but there's a bug with DMA:
--rambank1_size=128 --rambank2_size=128 --comment "adjacent RAM regions not supported for DMA"
The following is better because the RAM regions are not adjacent:
--rambank1_size=64 --rambank2_size=64
Copland might not boot with 136 MB of RAM so it might need this:
--rambank1_size=8 --rambank2_size=8
But the DBOF SCSI Mesh driver doesn't work with DingusPPC SCSI Mesh emulation yet so it doesn't matter.
I'll try to track down the std::invalid_argument bug.
145
47
Control-D in a DingusPPC window will get you into the DingusPPC debugger.
Control-F for full screen modes (integer scaling, full scaling, no bars scaling)
Control-Shift-F for full screen reverse direction.
Control- - and = for zoom out and zoom in.
Control-S for smooth scaling toggle.
Control-G for grab or release the mouse.
