[SOLVED] Macintosh SE works but has no sound
ACGuy
6
Spain
Hello, this is my first post here after years of lurking around. I ended up registering because I’d need some help with my Macintosh SE. Sorry if this post doesn't belong here.
After not using it since January, I started playing around with it the other day, and suddenly, when using it, it made an ugly noise (that came from the speaker), and since then, there’s no audio coming out of it. Neither from the speaker nor the headphone jack on the back. Also, the computer now shows a checkerboard pattern for some 10 seconds (check image) before booting up normally. The computer is usable, but there is no sound whatsoever.
I looked around the web for some schematics and run into the Bomarc ones. I used this one to check the audio path, from the BBU to the sound chip, and to the speaker. The traces seem okay, there’s continuity where there should be.
Seeing the schematics, I see the sound chip is also responsible with the RESET signal to the CPU, and there are capacitors around (C37, C32, C36 and C34). I thought, maybe any of these could have gone bad and it’s causing some issue, so I replaced them all (and I took good care of using a 1uF cap for C36). No luck. I kept the old caps, just in case, though.
I don’t have (easy) access to an oscilloscope, so I started measuring with the multimeter, and this is what I found:
1) All voltages seem pretty spot on, so I don’t think there’s any power supply issue.
2) The RESET output (pin 5), takes like 10 seconds to go from 0 to 5 V. This may be the cause of the checkerboard pattern, I think?
3) The Audio input (pin 16, which is coming from the BBU chip) starts off at 5 V, and then goes to around 1.8 V
4) The Audio output (pin 10, which goes through what I presume is a filter – C34, R6, C2) starts at around 12 V (although I’ve measured 14 V sometimes, then goes down), and stays there. The “presumed filter” works, and 0 V get to the speaker. No short seems to exist between +12 V and this pin, neither between pin 11, 12 or 13 and this pin (pin 10).
Now, I don’t have any other working (or non-working haha) Mac SE logic board around to check what should be normal or not. I think both points 3 and 4 are a bit suspect, but I’d need someone to tell me what their SE reads at those points.
Specially, number 2 and number 4 makes me think the chip has gone bad, so should I try to find a replacement? Can I replace it with something else? I know it's a reset line monitor (I'll call it that way), and it also filters PWM audio (I think? Please, correct me if I'm wrong).
Thanks in advance.
I'll leave some images for reference:
This is what the computer shows now before starting up normally
Sound chip, BBU and replaced caps
Bomarc schematics
Solution
So, finally some good news! The Mac has sound again, and the "delayed RESET" issue has also been solved.
See that R5 resistor between pin 12 and 13 (the 560k one)? Well, on my machine that resistor seems to have gone bad, it measured like an open circuit. Sure enough, I got a new one, replaced it, and now everything is working as it should again :)
So now, we know a new thing about the sound chip.
Hopefully, someone will find this useful in the future.
Checkerboard like that indicates that the CPU is running, it's not being held in RESET and the ROM is working - you're experiencing a RAM issue. Check all the RAM SIMM's are installed correctly, and the jumper is left OPEN unless you're using 256k SIMM's
ACGuy
6
Spain
Hi Kai, I have 4 MB installed, and my logic board is the one with the jumpers.
I haven't touched them, but I can try reseating the RAM sticks, but I'm a bit scared the slots may break (they are the full plastic ones). Still, I'm confused as I can see the reset line being held low for the 10 seconds the checkerboard is shown, and then the compute is normal, except there's no sound. Is that due to RAM issues as well?
Thanks
ACGuy
6
Spain
Hi Kai, I gathered the necessary courage to remove the sticks 😅
Still, no luck, each pair seems fine on its own, the Mac reporting 2 MB when testing each pair on their own, and 4 MB when testing the complete set.
So RAM seems fine.
A RAM issue seemed weird to me as, I stated, the computer boots up normally, only thing is that there's no sound (either the chime, nor anything else) coming out the speaker or the headphone jack, and that it stays for around 10 seconds on the checkerboard screen before booting up normally.
These two issues are what make me think that there could be something going on with the Sony sound chip, as it manages both the sound (duh) and the RESET line. I'm "concerned" for this line as it looks to stay low for those 10 seconds that the computer shows the checkerboard pattern.
On the other hand, as for the audio, I've been trying to test pin 16 (audio input to the sound chip coming from the BBU) while the computer is supposedly making sounds, and it stays at around 1.8 V always (although, as I'm using a multimeter, I think this reading might actually be the DC offset... I need to get an oscilloscope of my own).
So I'm a bit lost here. I don't think the BBU is bad, as it'd be weird that only the sound part of it has gone wrong, while the rest is okay. The computer once booted, works normally and doesn't lock up.
Could anyone tell me what their SEs read on pins 10 and 16 of the sound chip? Just to compare with mine.
ACGuy
6
Spain
Hi again,
I've kept looking at this, and now, instead of a perfect checkerboard, it gets a bit scrambled up:
Still, the computer ends up booting normally, and it's fully usable. All RAM seems to be detected, and I've run Apple Personal Diagnostics 1.1.1 RAM tests (both long and short tests), and all seem okay.
While the computer is showing this on screen, the RESET line is hold low. When it starts booting, the RESET line is high.
I should also mention, that if I press the reset button, the computer takes like 10 seconds to restart, time in which the RESET line is hold low.
Now, as for the audio:
(I guess the spikes are the result of using a non-compensated probe).
These are two oscilloscope screenshots of the BBU audio out (actually, it was measured at pin 16 of the Sony audio chip). The two of them show that, when there's something that should make some noise, the signal out of the BBU changes.
Unfortunately, the signal that is going out of the audio chip to the speaker (pin 10), it's fixed at 11-12 V. It's a straight line, with no changes whatsoever...
Both of these are making me think the Sony chip has started to act up. I've checked the voltages out of the power supply (both loaded and unloaded), and I can't see any ripple. Voltages seem stable. So, in my mind, the RESET line shouldn't be held low for so long.
In the next days, I'll get a spare Sony audio chip, and I'll make some further tests.
If someone has any other ideas, or thinks I'm making some mistake, I'll appreciate it a lot :D
ACGuy
6
Spain
Okay, updates on this one.
I desoldered the old chip, and replaced it with a socket. Like this, I made some measurements, after manually pulling the reset line high, so the computer can boot normally: this shows that the output (pin 10) of the sound chip is low all the time (so there's no short between this and the 12V rail). The input (pin 16) behaves as described in my previous message.
Speaker is working (tested with a signal generator).
Now, bad news, I put a new chip (I got it from AliExpress, as of August 2025 they are still available), but I have the same issue: no audio, output pin is always at 12V no matter what, and the reset line is held low for like 10 seconds.
I'm a bit lost now, as I don't really see what could be wrong, and I doubt both chips have the same fault.
Could this be caused due to some power supply issue. I don't think the PSU is bad, as the computer is completely usable aside from the sound, but who knows...
ACGuy
6
Spain
Solution
