Did you attach the STL? I looked at your post but couldn't see it.If you make one let me know how it goes![]()
Kudos! The originals were nice until time's tide came along. They are incredible brittle now those buttons are. So yeah, good job!Here's the STEP and STL files to add the clips back to an original button. I'm tempted to make an extension of the original button to make it so it won't need to be pressed so much and get stuck sometimes like the original.
License under CC BY-NC-SA 4.0
There's a lot of play in the position of the top case.Is it just me or does the button always tend to want to go to the left?
First test printed. It seems pretty robust, so I'm pleased. I may make a few revisions though. I'll use the original button bit so that it looks original.
That model looks like it's a 3D scan rather than something that's been parametrically modelled. It looks pretty rough to me.I just did a 3D print from a STL file at https://www.printables.com/model/941283-apple-power-macintosh-7xxx-power-switch using a PRUSA printer and PETG material. I am not impressed. Perhaps I need to use a different filament material.
This switch look better.
Yes, the PETG was dry.Did you dry your PETG filament? That looks like classic wet PETG print issues to me. It does look like the file is a 3d scan and not modeled (you can see the faint raised part number on the surface), but it is a really good 3d scan that looks very clean to me.
You definitely need to print with supports (because of the curves and overhangs), dry your PETG, and maybe start with a reference cube or 3D Benchy first before trying to print this part again.
Thanks. I will work with one of the engineering students and set up a nylon sliced version. Though I did use Co-Pilot to customize my PRUSA settings. Here is the sliced screenshot.After my own disastrous PETG print (too flexible), I printed one in Nylon, and it works well. It won’t shatter the way my polyurethane casting from 2012 recently did.
