Kensington Turbo Mouse 5.0 Replacement Trackball — Pool Ball? 57.15mm/2.25in?
iantm
121
56
Great Lakes
I'm hoping someone can confirm or deny the diameter of a Kensington Trackball from an ADB Turbo Mouse 5.0 (Model 64210).
I've read at that it is the same size as a regulation pool ball (57.15mm / 2.25in).
That sounds sweet, but I wonder if anyone has had a negative experience actually using a pool ball, since it's considerably heavier. Does it cause more wear on the rollers?
I'd like to replace the stock off white ball with something more distinctive. A pool ball would be a good alternative to an OEM trackball. Unless it's easier to find one that fits than I think, because multiple generations of the ball are the same diameter. They're hard to find on eBay without the whole unit (I just need the ball)
jmacz
91
109
Yes, it is a 2.25” standard regulation size billiard ball. I have been using one in mine for a while.
But I did find that the one I got was so polished it was slipping on the rollers. I washed it with soap thinking it might be some oil but that didn’t help. I ended up using a blank piece of paper to depolitish it a bit and that solved it.
Reactions: iantm
iantm
121
56
Great Lakes
Great. I found an old ball with an interesting typeface. Had no idea some were double circled and all that.
