24” 2009 iMac, bad screen, lvds or both?
703
Hi everyone, my kids knocked my 24” 2009 iMac off their desk horsing around and ever since the display is wonky donkey. At first I suspected gpu and did have a compatible apple spare in my junk which is what is powering the mirrored external screen below.
The machine works as it should via the external monitor. I suspect at this point either the lvds cable or the lcd panel itself got jacked in the fall. Any thoughts or common sense tests I am not thinking about that could tell me which one?
614
If you have removed the 4 screws on each side and can remove the screen, you will see if there is damage on the video cable connector or not (on the motherboard). I would suspect the display itself. You can try some gentle "impact maintenance" around the lcd panel to see if anything changes (better/worse).
703
That is a good idea. I did take the lvds off from both ends and reattached it but it did not change the result unfortunately. I’ll give the panel a good couple whacks to see if anything changes. Don’t really feel like buying a new panel but whatevs, the Mac has mostly survived two boys and their youngest brother (he’s 2) just recently found the keyboard and mouse so I think the new/used panel is the way to go. They’re not too bad - $30 to 50 bucks round about on eBay.
